20 Most Recent
Canon IR2870 COPIER FOR 220 VOLTS ONLY Questions & Answers
How to format canon ir 2870 hard disc
The copier might have it's own facility for formatting the hard drive but the best way to format any drive is to remove it and fit it as a slave drive to a desktop or laptop PC and use the computer to format the drive with the requirement that if the software it contains in 64 bit the PC will also need to be running 64 bit software.
PAPER JAM HO RAHA HAI
Open the Fixing unit and change the fixing unit film . Clean the unit properly remove paper tears inside the fixing unit .....
Paper jam in fixing assembly
Open the fixing unit and open the fixing unit film open it and greasing it with white grease and fuser oil after it problem will be solve..
How can I open hard disk?
On the back side a rectangle cover having 6 screws and then inside the cover you can see the Hard disk and remove 2 screws of the Hard drive and pull the hard disk horizontally(Right to left)..
Canon ir2870e000007-0000 how solve
Replace the the Fuser film in the fixing unit....
Clear the error and restart the machine problem will be solve....
The white mark of the fuser film on the right side replace properly if you insert reversely same problem will be persist..
Error canon ir2870
It is a problem with the LASER unit BD(Beam Detection) mirror. Check the BD mirror connection for any loose connection. if the problem remains, replace the Image Processor board.
