20 Most Recent
M&S Systems DMC1CD 6-Disc CD Changer Questions & Answers
Burned audio disc will not play in M&S DMC1CD
Its possible that your units Firmware (software within many items to identify itself or make use of "things" that come their way) is out of date and fails to identify that disc. I also presume you finalized it to make it playable on other machines, you could try to copy it onto another brand of disc.
Another possible problem is your players optics (laser eye) has a surface dirt film on it so a eye cleaning disc may help (looks like a disc with soft brushes in a line on it) or that disc may be a little bad (warped etc) that that player does not like.
I have had many pass me by some very fussy with damaged discs while a few could not care less (within limits).
Hope this helps.......
The system won't eject the CD changer.
You will need to reset your system.
Turn on the master unit and select the CD as your source. Open the door on the master unit to show all of the speaker numbers, here you will find a small pin hole next to the number 5 speaker. Use a small paper clip, unfold it and stick it into the reset hole. Hold the pin there for a minimum of 5 seconds until the clock starts to blink. Hit the time button seven times to get a solid time again. After turn on the master power and try the CD player again.
In my case the disc cartridge ejected when i was resetting the system.
