20 Most Recent Hisense TL1700 17 in. LCD Television Questions & Answers
2answers
My Hisense lcd is lock.
This is how I got mine to work after weeks of struggling just trying to find a new remote (hisense is really hard to contact....).
1) Turn the TV ON. unplug the tv while still ON 2) hold down the "menu" button on the side of the TV and plug it back in. keep holding it down. the TV should turn on with the menu popping up. use the Vol <> keys and Channel <> keys to navigate the menu. go to the Vchip menu, and play around. I'm not sure what ultimately worked, but i changed the Vchip password to 1111, turned the reset menu to "on" and played around with the ratings settings (turning most of them to "u"s etc).
I went through this process several times and finally, the black background behind the menu turned to static. I played around with the channels, and the TV was unlocked. I turned the TV off, and then on again, and the channels showed up normally (no static). and it was no longer locked. I had to do the unplug thing several times, and was getting really frustrated looking for an "unlock code" in the manual (it just says press the button on the remote. so it was not really helpful).
But really, once you can just get to that menu you've made some progress, and just keep playing around with it until something works.
Best of luck!!
7/4/2018 4:29:24 PM • Hisense TL1700... • Answered on Jul 04, 2018
I have the Hisense TL2020
Replacing the Caps: won't do anything. Please do not waste your time, money and effort. The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size. Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
10/20/2017 11:11:48 AM • Hisense TL1700... • Answered on Oct 20, 2017
Hisense tl2020 will not power on
power supply issue..may be some bad capacitors simply replace them....dada....your prob solved happy to help
8/18/2017 5:55:51 AM • Hisense TL1700... • Answered on Aug 18, 2017
0answers
4answers
Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
5/5/2017 4:06:13 AM • Hisense TL1700... • Answered on May 05, 2017
Hisense Tv-how do I get the analog channels to come in?? Only digital channels are coming in.
Which country are u in? Most countries have shutdown their analogue TV now.
10/17/2016 1:01:23 AM • Hisense TL1700... • Answered on Oct 17, 2016
How do I connect my TV to the wifi
The TV must be in range of your wireless router in order for the TV to connect. You have to put the wifi password in the TV and sometimes the mac address of the TV into the wifi section of the router
7/23/2016 5:46:39 PM • Hisense TL1700... • Answered on Jul 23, 2016
Get 8 blinks when tv is turned on with no picture or sound
Check out your power supply since set is sort of dead with no audio or video.
3/27/2016 7:21:01 PM • Hisense TL1700... • Answered on Mar 27, 2016
My TV fell, I bought it on Friday. Pictures are not showing only hear people talk. Can it be fixed?
Contact the authorized service center.
9/22/2015 12:39:06 PM • Hisense TL1700... • Answered on Sep 22, 2015
My HIsenese TV color went black and white...How do you I fix the color
I would first try a different input and cable if possible.
12/3/2014 5:44:22 AM • Hisense TL1700... • Answered on Dec 03, 2014
How do I factory reset my hisense u939 phone
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
9/18/2014 11:29:31 AM • Hisense TL1700... • Answered on Sep 18, 2014
No sound out of my hisense tv
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
7/30/2014 3:56:18 AM • Hisense TL1700... • Answered on Jul 30, 2014
0answers
The buttons of the LCD is not working
Check whether the panel lock is set to ON. If yes, set it to OFF. Gopakumar Gopalan Google Refer its user manual for details.
4/21/2014 2:59:36 PM • Hisense TL1700... • Answered on Apr 21, 2014
The remote control is not working
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among its posts have details about it. Surf the site in "Mosaic" or "Magazine" view. It will make surf easier. http://electronicshelponline.blogspot.com/
4/21/2014 2:56:11 PM • Hisense TL1700... • Answered on Apr 21, 2014
Black screen but will still play DVD's and still have audio
Check and replace damaged component/s at its back-light inverter board, or repalce this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/
4/19/2014 8:39:39 AM • Hisense TL1700... • Answered on Apr 19, 2014
Hisense TL1700 17 in. LCD Television Logo
144 questions posted
Top Hisense Televison & Video Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hisense Televison & Video
Most Popular Question
hisenese tv color went black white
  • Televison & Video
