20 Most Recent Olevia LT27HVX 27 in. LCD Television Questions & Answers
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
Olevia LT27HVX... | Answered on Dec 15, 2017
If you wish to get some details; check the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Olevia LT27HVX... | Answered on May 21, 2016
Did you scan for channels after hooking up the antenna?
Have the tv scan for available channels in your area.
Should be on the tv menu to scan for digital or analog channels.
Olevia LT27HVX... | Answered on Feb 07, 2016
Sounds like main system control memory IC fault. Contact any service technician to replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Olevia LT27HVX... | Answered on Sep 01, 2015
When connected select the correct AV channel on the TV!
Olevia LT27HVX... | Answered on Dec 08, 2014
As you see in this picture, and AV cable will have these type of pins at both ends. Just see:
Like this. By which; Yellow colored one is meant to be connected to Video In to the TV, and the other end of it to the Video out of the device you do as source; like DVD,VCR LD player etc.
Similarly, the other two colored pins [2 of it] are meant to be connected to the respective colored sockets; both at TV & the source device. These two wires are audio connectors, Left & Right channel. It's quiet simple to connect; and no expertise is needed. Have keen look. That's all.
Gopakumar Gopalan Google
Olevia LT27HVX... | Answered on Sep 17, 2014
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Olevia LT27HVX... | Answered on Apr 11, 2014
Check and replace its tuner. Contact any service technician. Gopakumar Gopalan Google
Olevia LT27HVX... | Answered on Mar 11, 2014
Without its remote control, you can't get it out Shop Mode. If you wish to buy its original remote control, contact the authorized service center, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Olevia LT27HVX... | Answered on Mar 04, 2014
is it showing it turn its self up on the tv by the bars or is the sound just getting louder by itself
is your remote a learning remote and does your tv have a preset volume that when turned on its to goto
if showing by bars one of the buttons on your remote is stuck or needs cleaning and
quite possibly getting an outside frequency thats interfering with your remote frequency
but if no bars are showing the service provider company i noticed my self there tv programs are flauxing in sound for some reason this to me gets annoying
Olevia LT27HVX... | Answered on Dec 01, 2013
0028,0025,0021,0022. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Olevia LT27HVX... | Answered on Oct 27, 2013
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
Olevia LT27HVX... | Answered on Jul 03, 2013
Olevia LT27HVX 27 in. LCD Television Logo
185 questions posted
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
put tv in shop mode no remote
  • Televison & Video
