20 Most Recent Bunn 10 Cup Home Coffee Brewer Questions & Answers
2answers
My Bunn coffee maker leaks water.. How can I fix it?
probably a broken hose
7/7/2018 10:17:36 AM • Bunn 10 Cup Home... • Answered on Jul 07, 2018
Just bought a bunn and it sounds and feels hot on the tank but water not coming thru to make the coffee
This is a common question for the BTX-B. It's a commercial brewer that needs to be pre-filled prior to turning on.. It also needs to be filled again with a full carafe for it to brew properly. I have a link below that will explain how to set up and use this brewer. Aloha, ukeboy57 https://www.bing.com/videos/search?q=bunn+grx-b&&view=detail&mid=E6D1ADD550DA3DA5B120E6D1ADD550DA3DA5B120&&FORM=VDRVRV
1/20/2018 9:11:24 AM • Bunn 10 Cup Home... • Answered on Jan 20, 2018
CANNOT GET IT TO MAKE COFFEE. HAVE SIDE BUTTON ON AND WARMER ON. POT IS FULL, AND IT HAS BEEN ABOUT 45 MINUTES NOW, AND NOTHING HAS HAPPENED.
That would take a repair center to decide, but I would go with a burnt out water heating coil in the water reservoir.
5/31/2016 4:34:52 AM • Bunn 10 Cup Home... • Answered on May 31, 2016
Overflows the filter area and runs all over carafe & warmer plate
Phil, If brewer has not been cleaned in a while this happens. the 1st link is your manual for down load, page 7,8 tell how to clean to fix your problem, if it has a bad build up may have to run 2x. Also watch video. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.bunn.com/sites/default/files/care-and-cleaning/43097_0002d01_velocity_brew_manual_english-_bt_st.pdf Use Care Bunn Coffee Maker
4/27/2016 11:32:00 PM • Bunn 10 Cup Home... • Answered on Apr 27, 2016
2answers
Leaking a half cup of water from the bottom while brewing
Call bunn for replacement gasket free of charge per recall.
4/10/2016 6:21:31 PM • Bunn 10 Cup Home... • Answered on Apr 10, 2016
How do you drain water from reservoir
I would unplug it . Wait till it cools, take the top off and push a small tube down inside the water tank but long enough to come out and get below the bottom of the tank and syfon it out.
4/1/2016 6:51:42 AM • Bunn 10 Cup Home... • Answered on Apr 01, 2016
2answers
My Bunn BX-B coffee maker
Did you check the switch on the side of the machine(vacation switch) to make sure there is orange/red showing? If it is, please give us a call with the model and code date and we can further assist you. Customer Service # is 800-352-2866.
2/19/2016 1:38:12 AM • Bunn 10 Cup Home... • Answered on Feb 19, 2016
How to activate a 10 cup bunn coffee brewer model nhb?
I don't understand the question, but here is a try. 1 - put in two pots of water. 2 - put in third pot, the water should start coming out Allow the water to heat (thirty minutes) then put coffee in filter housing, put in one pot of water, put empty pot on warmer, close lid, wait for brew cycle, enjoy coffee.
12/25/2015 6:29:44 PM • Bunn 10 Cup Home... • Answered on Dec 25, 2015
Water and grounds running over before going into carafe
Be sure the hole in the bottom of the filter basket is unobstructed. You may need to clear it or enlarge the hole if it isn't draining properly.
11/16/2015 8:31:30 AM • Bunn 10 Cup Home... • Answered on Nov 16, 2015
Can I dump water out of reservoir and refill
To empty the reservoir, you need to turn the whole unit upside down while holding it over a sink or outside on the ground that can get wet. Be sure to turn it on and wait for the water to heat up before brewing a pot of coffee.
11/16/2015 8:26:19 AM • Bunn 10 Cup Home... • Answered on Nov 16, 2015
Very loud when heating
It's the sound of the water expanding quickly as it's nearing its boiling point amplified by the enclosed water tank inside. Normal.
10/30/2015 4:02:30 PM • Bunn 10 Cup Home... • Answered on Oct 30, 2015
Bunn Home coffee pot
If you remove the top , then remove the water basin, you will see the heater. At each end of the heater (inside a white tube) is a thermal fuse. Will read like any other fuse with a meter. They carry them at radio shack as well as other places. The temperature is on the side of the fuse. Needs to be replaced with the temperature.
6/19/2015 4:35:48 AM • Bunn 10 Cup Home... • Answered on Jun 19, 2015
Was working this morning. now will not heat water and burner light will not come
High heat protection device just gave up. Time for replacement. (I've had several)
4/7/2015 12:04:32 AM • Bunn 10 Cup Home... • Answered on Apr 07, 2015
I unplugged my bunn coffee maker now the water won't heat as if there is no electricity but there is????
I would guess that the wire or plug in bad. It could also be the off an on switch
1/31/2015 5:40:06 AM • Bunn 10 Cup Home... • Answered on Jan 31, 2015
Why dos the maker only put part of the water when making coffee
Hi Rose, My mother-in-law had a similar problem and I found that a transparent film coated the entire inside of the reservoir (you can see if yours does too by feeling the inside of the tank as deep as you can reach). Once I got it clean, it began making full cups of coffee again just like it did when it was new. Here's how I got it working for her. Her tank has a fine meshed stainless steel screen over a "small valve" on the bottom of the tank secured with 3 small phillips screws. I removed the screws and took out the valve. The screen "looks" clear - but the same transparent film on the tank walls was coating the screen, too. As a result water flow thru it is significantly reduced - so it takes longer for water to pass thru it - resulting in "short" cups of coffee. The screen must be cleaned or replaced. I opted to clean it with an old tooth brush and soapy water. I then flushed the soap and the film from it while holding it under a stream of water from the faucet. I looked at the volume of water passing thru the screen to be sure it was cleared well. When happy with the flow, I resecured the valve to tank (after washing the tank in the top rack of the dishwasher as per the instructions on the underside of the tank lid). The film is a type of growth - like algae. To help prevent regrowth or slow it down; do not let water sit in the tank all the time. Pour only enough water in the tank that you'll need for the next 8 to 12 hours - better yet - dump the remaining water out after each "batch" of coffee you need to make. Do not let water sit over night or for any longer than necessary. Be sure to WASH the TANK regularly in the top rack of the dishwasher - as per the directions. I hope this helps & good luck!
12/26/2014 5:35:13 PM • Bunn 10 Cup Home... • Answered on Dec 26, 2014
Bunn 10 Cup Home Coffee Brewer Logo
243 questions posted
Top Bunn Coffee Makers & Espresso Machines Experts
vince
john h
ADMIN Andrew
ADMIN Andrew
Are you a Bunn Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Bunn Coffee Makers & Espresso...
  • Bunn Coffee Makers & Espresso...
Most Popular Question
  • Coffee Makers & Espresso Machines
