20 Most Recent
Canon CanoScan LiDe110 Questions & Answers
Canon Lide 110 scans the image in upside down. Is there a setting to flip it automatically?
Unfortunately, that's normal for this particular model. If you read the manual, or in this case the Quickstart Guide, you'll note that the top left corner is meant to go into the arrow corner. I'm annoyed with it too. You can always do it in Post-processing by doing two "turn image 90 degrees". If there would be a setting, it would be in the scanning program as the driver for this scanner has no settings available; you would have to check to see if there's a 'reverse image' setting in the program, though I doubt it.
How can unlock switch error code: 2,179,16
you have to run wire from you main router to the switch and put it in the in port. then you can plug in your computers from there. now if you have anew er one and it is wire less you still will hav to run a wire to the router. unless you get a repeter then all you have to do is log onto your routher and then use it like your main router
