20 Most Recent Humax DRT800 TiVo Video Recorder Questions & Answers
I own a Humax PVR9300t DVR. The set will not now
Time for a new machine I think. Sounds like corrupted memory - fortunately the loader is still working - so you may be able to do a software update. So search the web to try and locate the last software update image and apply that using a laptop, with a USB to Serial converter cable, and the Humax windows firmware update tool. Not sure that any of that is still around given the age of the machine
12/4/2017 9:42:27 AM • Humax DRT800... • Answered on Dec 04, 2017
How do I connect my Humax TiVo Dvr to to the free dish network apartment system?
Hi Lannie, my name is Mike Houston a Social MediaRepresentative at DISH. Connecting a TiVo box to an existing DISH connectionwill depend on a couple of things. Is there a DISH receiver in the apartment?What kind of connections do you have for the TV, HDMI, RCA, or Coax connections?I will send you my e-mail so I can assist you better; [email protected].
5/13/2012 1:27:44 PM • Humax DRT800... • Answered on May 13, 2012
0answers
I want to get an
Hello
I've with me the manual you needs. Send me you mail ID; either by Fixya or to me as I can't upload it to you through this site, it contains mote than 4Mb. Get it by return mail as an Adobe Arobat document. Point out your need also by mail, as I may forget this. Ok
[email protected]
2/10/2011 4:23:11 PM • Humax DRT800... • Answered on Feb 10, 2011
How can i program the Humax remote control
In the Setup Menu, Go to Remote,
Select your TV Type and try the different codes.
7/5/2010 5:58:23 PM • Humax DRT800... • Answered on Jul 05, 2010
2answers
Where can i get a user manual for a Humax 9300t pvr
u can get it on internet click here
7/4/2010 11:43:39 AM • Humax DRT800... • Answered on Jul 04, 2010
I have a 9320 humax hard drive recorder which
This may help, especially if an update has gone wrong;
Turn off
Unplug aerial and turn on
Perform a defaults reset (you'll lose scheduled recordings and any changes you have made to settings)
Turn off
Plug in aerial
Turn on and perform a second defaults reset.
If that doesn't do it, please repost.
Regards
Zahc
5/10/2010 8:28:51 AM • Humax DRT800... • Answered on May 10, 2010
2answers
Hi retuned my humax pvr9300t and it has retuned but
sounds like you are now picking up 2 transmitters, 1 Winter Hill, 1 welsh- Moel y parc. Due to the increased strength of the new Moel y parc signal
see http://www.digitaluk.co.uk/postcodechecker/main/trade/pr25+3ss/1/0
You can see its the channel 46 in orange thats your problem
Do the same retune but unplug the aerial until it gets past 46 so that it only finds the channels 56 and above that are from Winter Hill.
Bad news is that for you it gets worse when the extra channels come on next month. Looking at the aerial and maybe playing with attenuators might filter out the Welsh one
12/25/2009 8:24:06 AM • Humax DRT800... • Answered on Dec 25, 2009
Connecting my Humax Series 2 Tivo to a Motorola HD DCH3416 Cable Box
Yes, the Tivo will just record in standard definition, instead of high def.
You can still hook the two up together, though.
What I would suggest (and have done in the past) is this:
Split the cable coming out of the cable box.
Hook one up to your HD cable box, and the other up to the Tivo.
Hook the output of your HD cable box to one HD input on your TV
Hook the output of your Tivo up to a different (non-HD) input on your TV.
This will allow you to watch HD while recording standard definition, and vise versa.
Running the HD through the Tivo will work, but will limit you to not be able to watch HD through it.
3/26/2009 1:07:17 PM • Humax DRT800... • Answered on Mar 26, 2009
Celcus LED28272HD what is the tv code for humax remote control
You did not mention model of remote control. You can download the required manual for your remote control from following link. Remote Control Code List ' HUMAX-United Kingdom (humaxdigital.com)
12/31/2023 11:58:05 AM • Humax Televison... • Answered on Dec 31, 2023
Humax 5000t does not find HD channels when scanning
If your Humax 5000t is not finding HD channels during scanning, there could be a few potential reasons for this issue. Here are some troubleshooting steps you can try:
  1. Check signal strength: HD channels may require a stronger signal compared to standard-definition channels. Make sure your antenna or cable connection is secure and properly aligned. You can also try repositioning the antenna or cable to improve the signal strength.
  2. Perform a full rescan: Sometimes, a full rescan can help resolve channel detection issues. Go to the settings or menu of your Humax 5000t and find the option to perform a full rescan or channel search. This process may take some time, so be patient and allow it to complete.
  3. Update the firmware: Outdated firmware can cause compatibility issues and affect channel scanning. Check if there is a firmware update available for your Humax 5000t. Refer to the manufacturer's website or user manual for instructions on how to update the firmware. Follow the recommended steps carefully to avoid any potential issues.
  4. Verify broadcast standards: Ensure that your Humax 5000t is compatible with the broadcast standards used in your region. Different countries and regions may use different broadcast standards for HD channels. Check the specifications of your Humax device and confirm that it supports the specific HD broadcast standard used in your area.
  5. Reset to factory settings: As a last resort, you can try resetting your Humax 5000t to factory settings. Keep in mind that this will erase all your saved settings and recordings, so make sure to back up any important data beforehand. Look for the reset option in the settings menu of your device and follow the on-screen instructions.
If none of these steps resolve the issue, it's advisable to contact Humax customer support for further assistance. They can provide specific troubleshooting guidance based on your model and help you resolve the problem with HD channel detection.
7/14/2023 6:07:31 PM • Humax Televison... • Answered on Jul 14, 2023
Humax FVP-5000T Freeview Play Recorder. I cannot connect FVP-5000T to the internet. LAN is working plus all other internet devices.
Question edited for a lot more clarity. Question moved to Humax category. " I have tried all suggestions in your manual " Not OUR manual, we are Fixya dot com, we are nothing to do with Humax, we are not who you think we are. First, fully disconnect all devices from mains power for 15 minutes, router, television and the Humax Box. Plug in the router first, then the Humax and finally the television. It will take about 15 minutes for them all to come back online after the reset and all recognise each other. This is called a 'Power Cycle' and reloads all the software and connections. Then try again. If that doesn't fix it, you can fully Factory Reset the Humax unit, or you can just go into Settings and put the router settings back in SSID and Password. https://www.google.com/search?q=humax+fvp-5000t+reset ..
6/11/2023 4:32:31 PM • Humax Televison... • Answered on Jun 11, 2023
It reads: The file cannot be changed
It's possible that there may be a software issue with your TV or Humax box that's causing this problem. Here are a few troubleshooting steps you can try: Update the firmware: Check if there is any firmware update available for your TV or Humax box, and if there is, install it. This can often fix any bugs or issues that may be causing the problem. Check the file format: Make sure that the recorded programs are in a supported file format. Some TVs and media players may not support certain file formats, which can cause playback issues. Reset the TV or Humax box: Try resetting the TV or Humax box to its default settings. This can sometimes resolve any software issues that may be causing the problem. Contact support: If the issue persists, you may need to contact the manufacturer's customer support for further assistance. They may be able to provide additional troubleshooting steps or suggest a repair or replacement if necessary.
2/24/2023 2:28:38 PM • Humax Televison... • Answered on Feb 24, 2023
Humax DRT800 TiVo Video Recorder Logo
Popular Tags
18 questions posted
Top Humax Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Humax Televison & Video
Most Popular Question
get user manual humax 9300t pvr
  • Televison & Video
