20 Most Recent
GALAXY Microsystems 25.4 cu. ft. Side-By-Side Refrigerator with Filtered Ice and Water Questions & Answers
WATER DISPENSER ON GALAXY SIDE BY SIDE REFRIGERATOR DOESN'T WORK
Sounds like if your ice maker is still working, you're having an issue with your filter maybe freezing. Check to make sure your water filter isn't froze. What you're talking about with the overflow is a coincidence, but unless the internal wiring for the unit inside of the dispenser got damaged, i doubt thats the reason why. It's either a frozen filter or bad water valve. Try dethawing the filter or taking it out and seeing how much pressure there is built up in it. There's also a water reservoir in the back of this unit that may be froze too.
11/28/2013 3:41:11 PM •
GALAXY...
Answered
on Nov 28, 2013
I have a Galaxy 25 cu. ft side by side with ice
it appears as though you have replaced everything in the defrost circuit.. there is no mechanical timer, the defrost control is the circuit board up by the other 2 thermostats/cold controls, damper control box..
either theres a bad connection somewhere (could be a bad moly plug connection) or just a defective component you replaced..
the defrost thermostat should only have continuity when its frozen, once it warms it should open signaling the defrost control that the cycle is complete and to once again begin cooling..
hope this helps,
best of luck,
ttfn
10/22/2013 11:46:16 AM •
GALAXY...
Answered
on Oct 22, 2013
