20 Most Recent Reddy R60A Utility Heater Questions & Answers
REAL FACT is: If all individual components of the heater are at 100% but the air pump pressure is not on it's mark, then the heater WILL NOT continue to run!
Air Pump Pressure is directly related to fuel delivery. Read that statement again! It is the most important line of text on this website.
If the pump pressure is incorrect, then, the fuel delivery will be incorrect. As a result, the heater will not run to specs.
Instructions for setting the air pump pressure:
Air pump pressure is the pulse of the heater. Pump pressures range from 3 psi to 6 psi depending on heater BTU size (see chart below). A loss of ONLY 1 psi translates to a 30% to 17% loss of FUEL FLOW (starvation). You must know the specified required pressure and set the pressure accordingly.
Heaters with Hot Surface Ignitor technology are extremely critical to pump pressure. If the pressure is off by 1/2 psi, the heater may run for 5 seconds, then shut down because of IGNITION FAILURE. The only way to correct this problem is to set the pump pressure to DESA's recommended pressure specification.
  1. The FIRST STEP in diagnosing any heater problem should be checking the output of the air pump. Determine the air pressure required for the heater model that is being tuned. The air pump, in turn, is responsible for fuel delivery.
  2. If you do not know the required pressure look for a decal on the side (usually) of your heater. This decal will state the model number, serial number, fuel capacity, pump pressure, etc.
  3. If your plastic end cover looks like this......
m29609t.jpgM29609 has 2 threaded holes. The hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
or
m16545t.jpgM16545 has 2 threaded holes. The shorter projection with a hole on the left has a square plug inserted. Remove the plug. Screw in the nipple end of the gauge into the threaded hole. Check for air leaks with soapy water.
4. The other hole (longer projection) has a screw with a hole which adjusts a ball and spring relief valve assembly. Carefully adjust the screw until the gauge is reading the pressure level that is specified on the heater's label. If operating properly, the pump should produce more pressure than is required to operate the heater. The relief valve allows the excess air to escape before being sent to the nozzle.
5. Replace plug. Test for leak.
6. If you are unable to reach the desired pressure spray soapy water around the seal of the end cover- at the same time check the plastic cover for a crack. A cracked end cover will not allow the heater to perform properly and will not allow for an accurate reading. The pump must be set at the specified pressure in order to have adequate fuel delivery an adequate fuel atomization. Replace if needed.
7. If you set the pressure to specs and the heater does not perform properly or the cone does not glow a soft red, then check for other fuel delivery problems such as a clogged fuel filter, cracked rubber hose, clogged or worn nozzle, or a cracked nozzle adapter. Soapy water lightly sprayed in these areas will quickly identify the problem most of the time. Any air leak will create problems.
Reddy R60A... | Answered on Mar 04, 2015
Amazon and Ebay has them. $35 on Amazon. I found one on Ebay for $25 with free shipping
Reddy R60A... | Answered on Dec 06, 2013
Before I went replacing anything, I'd open the right access (looking from the front)panel. Pull the black feed hose off of the nipple on the the filter assembly. Carefully remove the filter barrel, which will be sticking down in the kerosene tank drawing the fuel out.With a flat tip screwdriver, rotate the plastic piece on the bottom of this assembly. Mine is red and looks like a little plug with a screen filter, shaped like a funnel. It has a friction fit so it will not be threaded. Pull this out and see if the fliter has dirt or debris in it. Blow it out with compressed air or wash it with a solvent. Replace the filter and reassemble, plug it in and turn it on. 98% of my early shut down or fuel issues are resolved by doing this. Doesn't take much to restrict fuel flow in these heaters enough to shut them down. Good luck.
Reddy R60A... | Answered on Dec 13, 2011
resolder the board
Reddy R60A... | Answered on Aug 01, 2011
There are a host of things that could cause this problem. Here are just a few:
  • The air output and input filters may need cleaning.
  • Air intake filter may be clogged.
  • Fuel filter needs cleaning.
  • Contaminated Kerosene.
Here's a link that will help you further. Be sure to take a look a page # 8 (Trouble Shooting). You can download and print this for future reference.
http://www.desatech.com/manuals/Construction%20Heaters/113893-01.pdf
Hope this helps you solve your problem.
Reddy R60A... | Answered on Mar 02, 2011
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Reddy R60A... | Answered on Feb 15, 2011
Hi and welcome to FixYa, I am Kelly.
Download this service manual:
http://www.bealsmotor.com/Desa%20Hot%20Surface%20Manual.pdf
You may have a dirty Photocell as discussed on page 19 but you can have other issues. The manual will help you sort it out.
Things to look at are:
  • Photocell
  • air filters
  • fuel nozzle
  • fuel hoses
  • fuel tank cap
  • fan clearances
Everything I listed is covered in the manual link at the top of this post.
Thanks for choosing FixYa,
Kelly
Reddy R60A... | Answered on Feb 14, 2011
Clean or replace your photo cell. Make sure your air pressure is set right,Remove your nozzle and blow air thru it . To test your photocell use a muti-meter hooked to two wire and hold flashlight over the end of boot see if ohms increase if not it junk,replace it.
Reddy R60A... | Answered on Feb 08, 2011
Check your in tank fuel filter
Reddy R60A... | Answered on Jan 27, 2011
no not hot enouph
Reddy R60A... | Answered on Jan 26, 2011
The answer may not be that simple. It will be a process of ruling things out. First check fuel level, then check fuel filter, check to see if the photo sensor is dirty, then check the intake and exhaust filters. If these check out then you need to check pump pressure. Since I am not as familiar with this brand as I am with Dayton you will need to consult your operators manual or the manufacturer for pump pressure specs. If the pressure isn't high enough you will to adjust it to the currect pressure. You should find the problem prior to this point.
Reddy R60A... | Answered on Jan 22, 2011
heatman101
Reddy R60A... | Answered on Jan 18, 2011
The first thing I would check,is the photo eye,it is near the flame ,and faces the element ,sort of.It may be dirty,remove the photo eye and clean it with a small amount of windex,or the same sort of cleaner,clean it two,to four times with a fresh paper towel,then replace it,if the photo eye can not see the flame,it will cut the fuel off and this could be the problem.If this was helpful,please let them know,thank you,please rate,I also have a pdf manual for the ready heater.
Reddy R60A... | Answered on Jan 07, 2011
Reddy R60A Utility Heater Logo
Popular Tags
85 questions posted
Top Reddy Heating & Cooling Experts
Paul Carew
Superior Maintenance
Brad Scarpetta
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
View Most Popular
  • Reddy Heating & Cooling
Most Popular Question
reddy heater runs little shuts off
  • Heating & Cooling
