20 Most Recent
PC Chips (M925G) Motherboard Questions & Answers
D:\ application can not run in Win32 mode
hi
go to start-run c:
if u can open it your sys is malware infected if u hace winxp sp2 pro and fat32 or ntfs partition.
scan your sys with avast ,qiuck heal and symantec update
Board: ECS M925 1.0 manual
Try this
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=141&DetailName=Manual&DetailDesc=M925(V1.1a)&CategoryID=1&MenuID=39&LanID=0
or
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=86&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
ECS M925 1.0 MEMORY UPGRADES
ECS M-Series M925
it looks like your motherboard will only take 2 gb of ram 2x1 gb of ram
PC2100 266 Mhz
2GB (2X1GB) Kit
M-266-1024X2BD10 or
PC2700 333 Mhz
2GB (2X1GB) Kit
M-333-1024X2BD10 if you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system
you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible
hope this helps
Dear Sir I
First go into BIOS Setup by tapping the DEL key as you power on your PC. (On some computers it's the F1, F2 or F10 key) On the first screen (usually titled System Information) be sure that your floppy dive is listed as Drive A: 1.44 MB 3.5" drive. It, probably is, so just exit out of bios setup and power off your computer. Next check and make sure that the 36 pin ribbon cable to your floppy drive is conected properly. The red mark on the side of the cable MUST be aligned with pin 1 on both the motherboard and drive end of the cable. The motherboard connector is usually labelled as to which end is pin 1, - if the drive connector is not labelled, look to se if the plastic guide on the top-center of the connector is lined up with the plastic guide on the drive. (If the cable is reversed, it wont hurt anyhing, the drive simply wont't work. If this doesn;t work, ty installing the drive in another PC to see whether or not the drive is bad.
If you have any additional questions contact me by clicking on the "Add a comment" link located under your problem description on FixYa. Also, if you believe that this information was helpful to you, please rate my solution using FixYa's "Solution Helpful" rating scale.
Best regards,
Yavacotech
Upgrade PCChips M925
According to PCChips, the maximum CPU & memory supported for all three is the Intel P4 Northwood (HT) 3.06 GHz 512K,533FSB,Socket 478 and 2GB (2 x 1GB) DDR 266.
Be sure you have the latest BIOS version for your motherbaord.
M925ALU (V7.3) must have BIOS : 030703s
M925G (V8.0) and M925G (V9.1b) must have BIOS : 050510s
Hope this helps you out.
Hello my name is Daniel,
I believe it's 2G, you can check here
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=271&CategoryID=1&DetailName=Specification&MenuID=1&LanID=0
