20 Most Recent Brother MFC-8860DN Printer Questions & Answers
2answers
Brother mfc is offline -
For my MFC, my PC says its ready and working properly. It really only works when I'm not connected to my cable modem. All PCs use it then. It's offline otherwise.
2/2/2022 8:22:45 PM • Brother... • Answered on Feb 02, 2022
3answers
How to switch from "offline" status to "online" status
I had the same problem with a Brother MFC-6490CW AIO printer. Here is how I resolved it:
Open the printers folder.
Right-click on the Brother printer and display the Properties page
Select the Ports tab.
In my system (Vista Premium), the selected port was a WSD port (whatever that means). Further down the list, there was a TCP/IP port that was obviously created by the Brother installation software. I selected the Brother-created TCP/IP port (which deselected the WSD port), applied the changes, and suddenly my printer was online. No idea what the difference between these two ports is, but I'll stick with the TCP/IP port until further notice.
2/2/2022 8:21:36 PM • Brother... • Answered on Feb 02, 2022
3answers
How to reset brother mfc
Hi. Here's the procedure.
1) Turn off printer
2) Press and hold menu button and turn on. Keep holding button until you see maintenance on display.
3) Press 88. This brings up parts replacement menu.
4) Press Up arrow until you see the part you replaced (laser, fuser, pf kit1, pf kit mp).
5) Press the OK button.
6) Power off and restart printer.
11/26/2021 8:46:29 PM • Brother... • Answered on Nov 26, 2021
5answers
Reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
8/3/2021 7:39:50 AM • Brother... • Answered on Aug 03, 2021
How to reset toner sensor for Brother MFC-8880DN Printer
The TN3130 & TN3170 actually have a physical reset and it is pretty easy to do. The second part of this video shows you how.
7/31/2021 11:47:06 AM • Brother... • Answered on Jul 31, 2021
My Brother MFC 8860 DN laser printer is making a terribel noise, chewing up paper and jamming
Picking up too many pages at once. Fluff the paper and try again
1/5/2018 10:17:18 PM • Brother... • Answered on Jan 05, 2018
Brother 8860DN won't work on Cisco switch
Go to the menu settings on the machine itself. Cycle through the options until you find the network settings. Make sure the device has network on and set the connection to DHCP on. save or back out and then restart the machine. It could also be a problem with your Cisco switch and the IP address ranges that the printer and switch have. You may need to specify an address in the printer settings to allow access through the Cisco switch.
11/22/2017 8:39:56 PM • Brother... • Answered on Nov 22, 2017
Machine error. unplug and call brother
unplug the machine for 15 to 20 minutes then try again. If not then within 2 seconds hit the keys in this order:
Menu-2-8-6-4-* (star key to left of 0) this may take a couple of attempts, but you will know when you are there because the lights will start flashing.
"maint. mode" then hit:
9-1-"set
and finally 9-9-"set"
this should clear up the error message if there is not a problem with the fuser unit.
9/15/2017 2:26:58 AM • Brother... • Answered on Sep 15, 2017
2answers
MFC8860DN SAY'S SCANNER LOCKED?? WHAT'S THE
Hello my friend.If you open the scanners door under the document cover is one switch that locks and unlocks the scanner.Move it to the position that shows that is unlocked.If this doesnt work it means the scanner lamp is in the park position and is stuck. You need to lean the printer away from the sheet feed side and bump it on the side. This should fix it. If it doesn't turn off the power and remove the two screws that hold the scanner lid on. Then remove the other 6 screws located under the lid on the left side while the lid is hanging from lid open sensor cable . After removing the base screws you can set the lid on the scanner again while you lift the scanner bed exposing the scan lamp mechanism. Push it a few inches in the machine and close the lid. You can do a test by powering the unit on and hold the lid open sensor button located on the bottom left of the lid. The system should initialize and bring the scan lamp back to the proper position. Turn off replace all screws and your done. If it doesn't work the first time push the scanner lamp more into the scanning area and repeat until works.
1/22/2016 3:58:19 PM • Brother... • Answered on Jan 22, 2016
My printer is showing the message "Machine Error" unplug and call brother. What does this mean?
get in a service technician to replace the power unit
11/4/2015 10:19:59 PM • Brother... • Answered on Nov 04, 2015
Mcf8860dn new toner new drum has what looks like a centre roller printing on my documents in the background.
its in your settings try the brothers web site for correct settings to remove logo background.
5/21/2015 3:38:53 AM • Brother... • Answered on May 21, 2015
My brother MFC 8860DN printer
Open it up from the back of the machine. Try reseating the fuser first. If that does not help, then you need to replace it. Probably the ceramic fuser element is going bad? It is either not heating up fast enough or heating up too fast. If you can print test sheets, and the text is too shiny, it would be a fuser that is too hot. If you can rub the text off the test sheet, it is not fusing fast enough and there is not enough heat.
Try ebay for a fuser. They are fairly simple to replace.
3/18/2015 6:59:25 PM • Brother... • Answered on Mar 18, 2015
2answers
How do I replace the fuse?
does your printer have no POWER when you turn it on? I’m happy to help further over the phone at https://www.6ya.com/expert/ron_9356d26241d4cbf7
3/18/2015 6:54:16 PM • Brother... • Answered on Mar 18, 2015
What is the code SC546 mean?
search error code . Brother MFC-8860DN Printer
3/18/2015 6:51:25 PM • Brother... • Answered on Mar 18, 2015
2answers
Where is the drum on the MFC-8860DN and how do I remove it?
The drum is part of the laser toner cartridge
Open the front door
Press the square button in the center of the paper receiving are, it is marked with a small triangle
Press and pull, it will open a door showing the toner cartridge
Pull out the toner cartridge
The top part is black and the bottom assembly is grey
There is a blue little latch in the right side of the cartridge
Press the latch and the toner cartridge will be release
Remove the toner cartridge.
You need to replace the grey bottom assembly with a new one
A compatible assembly, which will have a new drum, will cost around
$30 at amazon an oem around $70
Reassembly and reinstall in reverse of the disassembly I hope this was helpful
3/18/2015 1:08:19 AM • Brother... • Answered on Mar 18, 2015
I HAVE REPLACED TONER WITH THE CORRECT BROTHER TONER CARRTRIDGE AND THE MACHINE KEEPS TELLING ME TONER ERROR AND REINSTALL DRUM UNIT..HELP
Hi there, Below are instructions that I have found from the internet. Hope that they will help.
  • Open the front cover of the printer.
  • Hold down the Go button for 4 seconds until all the LEDs light up. Then release the Go button
  • Remove the drum unit and toner cartridge assembly.
  • Replace the drum unit and toner cartridge assembly back into the printer.
  • Close the front cover of the printer
  • Your drum unit should now be reset
  • MFC / DCP PRINTER SERIES 1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes. 2.Replace the drum unit and toner cartridge into printer. 3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit. 4.To clear this error message, you need to reset the drum counter as instructed below. 5.Make sure that the machine is turned on. For MFC users: To confirm you are installing a new drum, press 1. For DCP users To confirm you are installing a new drum, press the Up Arrow key 7.When the LCD shows Accepted, close the front cover. 8.Your drum is now reset. Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
2/26/2015 10:24:59 AM • Brother... • Answered on Feb 26, 2015
Brother MFC-8860DN Printer Logo
342 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
brother mfc offline
  • Office Equipment & Supplies
