20 Most Recent Brother MFC-8460N All-In-One Printer Questions & Answers
4answers
Need to reset 'Drum near end' warning on Brother MFC-8460N.
Open the front door
Press clear
then press 1
8/3/2021 7:40:27 AM • Brother... • Answered on Aug 03, 2021
How to configure Brother 8460N to scan to Synology DS412+
test
8/1/2021 7:21:31 AM • Brother... • Answered on Aug 01, 2021
3answers
When I try to scan a document on the MFC 8460N
Welcome to FixYa!
Try to print a document. If it does not print, do the following:
1. Unplug the power cable of the printer while it is ON. (Hard reset)
2. Disconnect the printer cable from your computer.
3. Shutdown the computer.
4.Turn the computer back ON after 30 second.
5. Connect back the printer cable to the computer.
6. Plug the power cable of the printer and turn it on.
7. Try to print a document first. If it prints, proceed to scanning.
What we are doing is that we are trying to see first if the printer is establishing connection with your computer. Make sure that the cables are properly connected.
Keep me posted for the developments.
Thank you for using FixYa.
Jas
3/2/2021 5:27:58 AM • Brother... • Answered on Mar 02, 2021
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
3/2/2021 5:27:31 AM • Brother... • Answered on Mar 02, 2021
4answers
Brothers mfc-440cn - unable to clean 51
The error indicates multiple problems, and needs to be serviced by a ASC Brother Center. Go to brother.com and go to support and then service center then enter your zip code or you can ship to us since we are a ASC Center for Brother.
2/26/2019 6:39:09 AM • Brother... • Answered on Feb 26, 2019
4answers
Brother 8460n Fuser Unit
Hit in sequence Menu,*,2,8,6,4
This will put it in maint. mode.
Press 88
That is parts counter reset, scroll down and hit ok on the part you want to reset the counter. :)
11/6/2018 4:45:32 AM • Brother... • Answered on Nov 06, 2018
Brother MFC-8460N All-In-One Printer Beeps 15 time every hour
Please see the control panel display (any error code or problem issue)
12/16/2017 7:47:02 PM • Brother... • Answered on Dec 16, 2017
I have a Brother MFC8460n
did you also enable overseas mode? https://www.voipmechanic.com/voip-fax-settings-brother.htm
10/3/2017 2:20:10 PM • Brother... • Answered on Oct 03, 2017
Brother MFC8460N was working great and now today
Try re-installing the scanner software - if you don't have the disc you can download it. The scanner is a very delicate mechanism so is easily damaged - if the software fix don't work maybe it is kaput
10/3/2017 8:30:31 AM • Brother... • Answered on Oct 03, 2017
I keep getting the message, "Toner error, replace drum unit". I have a MFC Brother 8460N. Jane
Have you replaced the Drum unit? Drum unit on Brothers can be reset if copy is good and you do not want to replace. If copy bad replace Drum. Rebuilt drums work as good as original at half price.
3/28/2017 8:12:06 PM • Brother... • Answered on Mar 28, 2017
0answers
How do i cancel fax confirmation page
Menu-Fax-Report settings-xmit-OFF-ok
1/21/2015 5:05:50 PM • Brother... • Answered on Jan 21, 2015
How to reset drum life on brother 8460
first open the front cover, Then press the clear\back button. When the machine displays "replace drum? press *00 and close the front cover
8/18/2014 9:56:37 PM • Brother... • Answered on Aug 18, 2014
2answers
My Brother MFC 9440cn keeps giving a paper jam
try seting the paper to A4 not leter
7/14/2014 4:15:03 PM • Brother... • Answered on Jul 14, 2014
Can send but can't receive faxes on MFC-8460N
Fax machines are ANALOG devices and will not work reliably on DIGITAL phone lines.
7/14/2014 10:22:18 AM • Brother... • Answered on Jul 14, 2014
Have changed setting to tray 1 instead of mp tray and printer will not change and still says no paper
Sensor that detects paper needs to be replaced. Same thing happened to my machine and I had to take it in to a Brother repair company. 1 hour service call
7/8/2014 3:27:15 PM • Brother... • Answered on Jul 08, 2014
Brother MFC-8460N All-In-One Printer Logo
443 questions posted
Norman Weimar
Norman Weimar
k24674
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
printer printing black horizontal lines
  • Office Equipment & Supplies
