20 Most Recent Hotpoint Aquarius WD640 Front Load Washer/Dryer Questions & Answers
Plug off the wall. There is a thin rubber tube going from the switch area to the exit near the outlet tube. Probably this is blocked. This tube should be free from any blockage; take out the top clip from this tube and blow into it - it should be free, clear the blockage if any and refit. This is the water level tube which tells the machine when to switch off water, etc.....
Hotpoint... | Answered on Jun 02, 2019
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Hotpoint... | Answered on May 18, 2019
F01 - Short circuit motor triac - Book a washing machine repair. F02 - Motor jammed tacho detached - Book a washing machine repair. F03 - Wash thermistor open/short circuit - Book a washing machine repair. F04 - Pressure switch jammed on empty - Book a washing machine repair. F05 - Pressure switch jammed on full - Book a washing machine repair. F06 - Program selector error - Book a washing machine repair. F07 - Heater relay stuck - Book a washing machine repair.  F08 - Heater relay cannot be activated - Book a washing machine repair.  F09 - Incompatible eeprom - Book a washing machine repair.  F10 - Pressure switch not sensing correctly - Book a washing machine repair.  F11 - Pump cannot be activated - Book a washing machine repair.  F12 - Communication error - Book a washing machine repair.  F13 - Dryer fan or dryer thermisotor faulty - Book a washing machine repair.  F14 - Dryer element faulty - Book a washing machine repair. F15 - Dryer element relay faulty - Book a washing machine repair.  H20 - Not fillings. Check tap, hose and inlet valves LOCKED - Check interlock - Book a washing machine repair.  Here is a list of fault codes. I hope this helps !
Hotpoint... | Answered on Nov 21, 2018
F6 error is apparently a motor fault. The
motor could be jammed, open circuit ,
burnt out. It may just be a broken wire
or connection come off. Check the motor.
Hotpoint... | Answered on Apr 21, 2018
Check all thermostats , check to be sure you have 220 volts coming into the machine. Use ohm meter & check from heater element to the heater case or cabinet to see if the element is grounded. Positive to element & Negative to case should show no ohms if it does it is shorted. Also heater circuit runs through a centrifical switch on the motor
so if the motor quits the heater shuts down so you don't have a fire. When the motor is not running the fan stops.
You could check this switch but it don't happen very often. check this switch last. Hope this will help you
Hotpoint... | Answered on Feb 02, 2018
My list of Indesit (Hotpoint, Ariston) errors does not include an 'F06'!
If you have not done so already try checking that thre is no drainage blockage/stopage.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Hotpoint... | Answered on Dec 23, 2017
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
All error codes at above link...
Hotpoint... | Answered on Dec 13, 2017
go to the parts website for Hotpoint for price or Google the part number and someone will post it for sale.
Try going to You-Tube for instruction video on replacing.
If it is still under warranty, call mfg or warranty company.
Hotpoint... | Answered on Nov 16, 2017
i can try to help you with this problem. if you pop the cap off the top of the agitator you will see a nut, once you take the nut off you should be able to jiggle the agitator in an upward motion to remove it then retrieve your wire and gently slide agitator back on so as not to ruin the splines if there are any. good luck
Hotpoint... | Answered on Sep 30, 2017
you could have a broken pipe on the filler or the seal has gone on the drum you would need to have a look, either way they are easy to fix or replace. drain pipe can leak if the pipe has come off the pump also check this but you will need to remove the case to get to look, always unplug the washer before touching any screws, remove case and look at the pipes and make sure they are seated in the right place.
Hotpoint... | Answered on Sep 09, 2017
You will need to replace the entire control panel assembly to cure this problem
Hotpoint... | Answered on Jun 29, 2017
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
906 questions posted
Top Hotpoint Washing Machines Experts
Eric Taylor
James Hehling
James Hehling
Level 1 Expert
Onofrio Taverna
Onofrio Taverna
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Washing Machines
Most Popular Question
machine fault code f13
  • Washing Machines
