20 Most Recent
Sony Ericsson T230 Questions & Answers
OPEN MMS
call the service provider get the settings for MMS and GPRS and use it....
I have c903 sony ericsson when somebody calls i
on the main standby screen type ->*<-<-*<-*<-* here -> means right joystick button and <- means left joystick button, don't meter if the menu opens after first click u continue typing. then go to the service tests, you can increase the volume here and go to that tests menu and then speaker test and follow the instructions if u don't hear anything then your speaker is faulty so get it replaced by a technician, your problem will be solved!
reply and revert back for more support and ratings!
Problem in sending sms
if you are unable to send text messages(sms) to anyone then there is a problem with the message centre no. refer your manual to fine the message centre no in your phone(probably in text message settings) and check if its compatible with the service provider.( call the customer care of service provider to get the message centre no) and enter it and save it. then you will able to send text messages.
Puk code of T230
it seems like you have entered the PIN code incorrectly 3 times, you iwll have to contact your sim card network provider to obtain the PUK code as it is the only way.
Screen display
You got a problem on the backlight of you cellphone display. Find a customer support that can provide you assitance and repair for your cp.
Sonyerricson T230
saya punya semc dari SE p910i bisa gak kalau sy gunakan untuk kabel conect usb ke internet melalu PC compt
Keypad code
help me how to shown the code for sony ericsson unit of T230
Nokia 1200 restarts
Try restore factory settings with 12345 in settings, if dont works try to flash the phone if you are tech..
Black list
For the same, you'll have to connect your Phone to your PC and create a folder `Black List' in your Phone Memory/Memory Stick.
Sahaja Yoga is the Mahaa Yoga. This is the Only Way to Save the World and is Free of Charge.
Sony Ericsson T230 Can Not Hear Caller
take it to any technician just need to change its speaker and it will not cost much, u can still use ur phone. it is very small problem, just need to change its speaker.
