20 Most Recent
Samsung SGH-e317 Questions & Answers
Puk number
PUK stands for Personal Unblocking Key. This is a unique eight-digit code specific to your SIM card. This is required when the PIN number to unlock your mobile phone is entered incorrectly 3 times. You are then given 10 attempts to enter your PUK code. If an incorrect PUK code is entered after the 10th attempt, you will block your SIM card permanently and will require a new SIM card from your mobile phone provider. PUK codes can be obtained through the following ways - The PUK code is in your SIM card documentation Starter Pack. If you do not have this then - Please contact your phone service provider. Your cell phone service provider can give you the PUK code once you give them your account details and they have confirmed your identity. For details to obtain the PUK code for the SIM card, please click on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
My mobile battery not charging
POWER SUPPLY & BATTERY PROBLEMIf thecell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.ORThe charge adapter is faulty. Test the voltage on the adapter plug with a multi-meter, the voltage should be slightly higher than the voltage on the label on the charge adapter.
How to unlock a mobile model sgh-e317
There can be many ways to Unlock your phone. As far as i know unlocking by codes is the simple and safe way. I will suggest the website
Unlock-Zone.com which is doing good service and they were recommended highly in the cell phone forums.
I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
Cell got wet
well.. Sorry dear you have you get your mobile phone checked with the professional mobile repair shop that's the only solution you should be very luck you had used you mobile for a while after getting it wet . often mobile goes to drain after getting in water
SGH-E370
OK. I hear you. that really sucks. have you installed your phone into your PC ? if you did then you should try double checking on the files you send to your phone e.g : songs should be mp3 files. maybe that will help
