20 Most Recent Motorola Mobility RAZR V3 Questions & Answers
0answers
3answers
Voice record!!!!!!!
Press the big side button on the right. Hold it down while the phone is flipped open. Then it should work, hope this works.
10/8/2022 3:06:07 AM • Motorola... • Answered on Oct 08, 2022
2answers
Unlock code for moto bc50
The code is the last 4 digits of your number
11/12/2021 5:52:05 PM • Motorola... • Answered on Nov 12, 2021
2answers
No sound when phone rings
Look at the ring volume. Make sure it's not at zero. Let me know if that works.
11/6/2021 5:49:06 PM • Motorola... • Answered on Nov 06, 2021
2answers
I've got a Motorola V3 phone and I really need to
- Press "#"
--Once for "Numbers"
--Twice for "Wild Characters"
--Three times for "Non-Predictive Text"
10/20/2021 9:28:57 PM • Motorola... • Answered on Oct 20, 2021
2answers
Voice recording as ringtone
hi
nope you cant do that... its factory settings... sorry...
9/30/2021 2:01:41 AM • Motorola... • Answered on Sep 30, 2021
2answers
Voice recorder
the voice key is on the side of the display screen same side as pwr hold that moz-screenshot.jpgmoz-screenshot-1.jpgto record your voice let go when finished
9/23/2021 1:20:46 AM • Motorola... • Answered on Sep 23, 2021
7answers
Bootloader USB INIT
this happens to phones that have had water damage or something else and a way that might make it work is to take the battery out for no more than 60 seconds and put it back in and push the *,# and power buttons at the same time and if the blue screen comes up, while on the screen push the buttons and hold them until it goes normal. it worked for me
2/25/2021 9:22:31 PM • Motorola... • Answered on Feb 25, 2021
12answers
Blocking calls, motorola razr v3
Yes, sort of: go to Settings->Security->Enter lock code here if you've created one(otherwise ignore this step)->Limit Use->Restrict Incoming Calls From this step, you'll have to choose to restrict incoming calls from anyone NOT in your Contacts . You'll still get the voicemails and notifications of who called, but unwanted callers will go right to voicemail and you can call them back whenever you are ready.
10/2/2020 5:07:50 AM • Motorola... • Answered on Oct 02, 2020
24answers
My cell phone screen dont work ...help
This is a common problem, it has to do with the keypad flex. either the connector on the top part of your phone is unpluged or your flex is damaged. Open the top of the phone where the screen is at (4 torx screws) genlty remove the cover. you will see two connectors, one that goes to the camera, the other is the one you want. genlty pry it off upwards, I would also clean it with some IPA (rubbing alcohol) and a brush, re-connect it pushing down firmly, you will fill it when it connects. if it doesnt work, you can purchase a new flex, if you need repair help, let me know I can try to repair
10/2/2020 5:07:05 AM • Motorola... • Answered on Oct 02, 2020
37answers
My phone displays 'unable to charge' or no battery icon?
I plugged my phone up and all of a sudden got the message "Unable to charge" on it. I changed chargers (i had an extra one), i changed batteries (i had an extra one), and i swapped every combination imaginable.
My solution....
My Razr's plug has an opening to plug the phone that resembles a person's navel, and it got dirt and dust bunnies in it while it was in and out of my pockets. I was able to take an old tooth brush (or your new one if your really desperate), and got a can of office duster that you use to clean keyboards. Turn the can of office duster upside down for a second while you are spraying it and liquid will come out as you are spraying the connector. Immediately after that, use your toothbrush to work it inside the dirty connector to free it from anything that will keep it from making good contact. Then, hold the can of office duster upright and it will only spray air... and blow the connector free of anything that you loosened with the brush. Repeat this process if after all this it still doesn't work... because you have a REALLY REALLY dirty connector if it doesn't work after the first try.
10/2/2020 5:06:34 AM • Motorola... • Answered on Oct 02, 2020
2answers
Motorola br50
you need to take the phone and have the mobile unlocked......or try mobile2mobile.net
5/1/2020 1:15:26 PM • Motorola... • Answered on May 01, 2020
My phone won't switch on whilst charging. What's wrong?
model and make?
1/6/2020 3:32:33 AM • Motorola... • Answered on Jan 06, 2020
3answers
I have no sound in my phone
remove the screen protector
12/31/2019 11:18:24 AM • Motorola... • Answered on Dec 31, 2019
2answers
Sammi James is the best spammer expert on FIXYA
I would search google for "file recovery" software and run that on your microSD disk, just like you would a floppy or hard disk and see if it will find anything.
5/27/2019 12:32:22 AM • Motorola... • Answered on May 27, 2019
V3 Sprint , need replace cdma network setting
Contact your existing carrier of the Helpdesk of the manufacturer, I think could be ya best bet
2/14/2018 6:31:15 AM • Motorola... • Answered on Feb 14, 2018
4answers
BLOCK SERTIN CALLS
you will have to go into your call settings and select call barring and add the number you want to block
1/30/2018 1:30:44 AM • Motorola... • Answered on Jan 30, 2018
Motorola Mobility RAZR V3 Logo
9,393 questions posted
Top Motorola Mobility Cell Phones Experts
AFIFUL HAQUE MUFTI...
Level 1 Expert
vince
john h
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
RAZR Motorola Mobility
  • RAZR Motorola Mobility
Most Popular Question
blocking calls motorola razr v3
  • Cell Phones
