20 Most Recent
Dell E172FP 17" LCD Flat Panel Monitor Questions & Answers
Screen suddenly went blank except for a self test box
well in order to get rid of the self test window from your monitor... check the cable that connects your monitor to system tower & reset the connection... becase that is the only possible cause of the self test showing up on your monitor...
" as the self test option only appears when there is no video signal going from your video card to the monitor...
WHY IS THE GREEEN POWER BUTTON FLASHING ON MY MONITER AND THE SCREEN THEN GOWS BLACK
When the power light is flashing the monitor is not getting a stable signal. This is hard to answer without direct troubleshooting. Check the cables first, make sure they are connected securely. If you still have problems test another monitor you know works or move monitor to a computer you know works, this will determine if the monitor is the problem or not and tell you if it is your "graphics port or adapter". If another monitor works fine, use the working cables to test the "broken" monitor. If you have an "all-in-one" computer, ignore the above steps and use a start-up repair disk. The reason this is hard to troubleshoot is there are so many things to diagnose. More than likely your "graphics card" is failing. These are some tricks to repair. You can update the driver, buy a graphic card separate from the stock port.
How to get rid of main menu icon popping up
Anonymous,
Turn off. Disconnect the power cord from the rear/bottom. Press and hold in the power button for 10 seconds. Reconnect the power cord. Power on. If that does not stop it, it is broken and will need to be replaced.
Thank You,
Dell -Jesse L
Dell Social Media and Communities
What is vga/dvi cables
VGA and DVI is in the way the video signals travel. VGA connectors and cables carry analog signals while DVI can carry both analog and digital. DVI is newer and offers better, sharper display compared to VGA. You can easily tell them apart because VGA connectors (and ports) are blue while DVI connectors are white. Click the link below to see an image of them.
http://www.hardwaresecrets.com/imageview.php?image=8131
How do I make my PC get the video signal?
connect the vga/hdmi monitor cable to your pc and let the windows search wizards to detect your new hardware. follow the instruction or install the cd driver for your monitorJoel
