20 Most Recent
Dell E173FP 17" LCD Monitor Questions & Answers
Dell E173FP stuck in power save mode
Just had the same problem... what worked for me was simple. Unplug the cable from the monitor, hit the power button a few times until Dell screen poped up with a few color bars because it knew it was no longer connected to a PC. Then plugged the cable back in and all was fixed.
Has power but no display
Do the flashlight test. Shine flashlight on front of screen at angle and see if you can see an image or lettering. If so, it is probably inverter board. Let me know first if you have an image.
Black shapes stuck on lcd monitor
monitor may have died or someone might have dropped it?
no other explanation. monitors can be gotten fairly cheap now-maybe at a PC Recycling shop or get new
Monitor stuck in power save mode
Take the RAM out to be sure that is not causing the issue. If it is then make sure it is seated right and is the right kind and try again. If the video card is not initializing that would cause the monitor to not work.
My Dell E173fp monitor display doesn't work with my macbook
The fine print says it should work. Real life might be different. Do you have a genius bar, found at Apple stores, anywhere close? If so, make an appointment and let them make the connection for you. The genius bar is a free service and I've never found anything that they haven't been able to fix...and fix it quickly...if it's fixable.
Monitor power light blinking on and off but no picture
try testing the monitor on another computer. if you dont have an extra desktop or laptop to test with. take over to a neighbor or a friend. if the monitor still doesn't turn on or no signal. the monitor is defective and needs to replaced or repaired by a technician
good luck
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Dell Monitor in Power Save mode
Hello there:
i would refer to your users manual to see if there is a power save mode setting on the monitor it'self and to see how to adjust it or contact the manufacture of the monitor . ok ?
hope that this is helpful
DELL 1907FPT WITH PINK DISPLAY
The picture board on your monitor is bad, since it goes
off after it is turned on and the power led or button is on, it means the
board of your monitor has developed fault.
The best thing for you
to
do now is to take the monitor to a local repairer within your vicinity or any service center
to help with the replacement of the picture board
because the fault is not something you can fix yourself, in order not to
complicate issues.
Take care.
How do i reduce the size of a monitor
Hold down the ALT key.
Touch the SPACE bar.
Touch the S ("size" key).
Touch LEFT-ARROW key.
Repeatedly press the RIGHT-ARROW key to move the left edge of the window to the right.
Touch the UP-ARROW key.
Repeatedly press the DOWN-ARROW key to move the top edge of the window towards the bottom.
Touch ENTER to "commit" the changes.
I have a Dell 1707fp monitor. When I power the
I just fixed my for less then 1 minute. Here was the problem, when turn on the PC with the monitor connected. The screen appear like normal for about 2 seconds then shut off black but the GREEN power LED stay on, if i press the power off and turn it back on the screen act the same thing.
Here how to fix it, turn off the PC, unplug the monitor power cable then plug it back. The power LED will stay amber. Hold down both brights minus - and plus + same time, turn on the PC, keep hold the - and + buttons press the power button turn on the monitor.
You will see the screen back on, just hold for about 10 more seconds till you see the screen seem to stay on fine then realse them. That's it how i fixed my.....GOOD LUCK
Dell E173FP Monitor Problem
My Dell E173FPc exhibited this same problem as described by many people on this site. Having looked through the solutions I decided to investigate further.
Posted solutions point to a faulty 12V smoothing capacitor, dry joints on the inverter transformer or faulty driver transistors. All these were Ok in my case, but on closer inspection a dry joint was found on L202 – see picture.
Cleaning off the old solder and re-soldering fixed the problem.
So if your monitor exhibits the same symptoms carefully inspect all the solder joints of large components around the inverter.
