20 Most Recent Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30 Questions & Answers
0answers
High temperature light is always on
could be a leak. have it checked by a tech.
4/8/2009 12:27:55 AM • Hotpoint 3.5 cu.... • Answered on Apr 08, 2009
Hotpoint Freezer
Get a hold of CAMCO, they are the authorized parts/repair depot for Hotpoint
2/7/2009 1:46:58 AM • Hotpoint 3.5 cu.... • Answered on Feb 07, 2009
Have an RZA30 freezer thats not freezing
was the compressor running? if the unit fails to make temp at a given setting and the compressor is running then turning down the cold control will not make it colder. the thermostat is a switch that turns the compressor and fans (if you have fans) on and off. the different settings only change at what temp the compressor etc. turns off. make sense? so listen for that compressor if it is running and the unit is war you have refrigeration system trouble: restriction, low charge, leak, etc...
cant tell you which without more info.
4/23/2008 7:37:05 PM • Hotpoint 3.5 cu.... • Answered on Apr 23, 2008
What do the control buttons do on a Hotpoint Ice Diamond R134A do please?
Could you please recheck for the model number. R134A is a reference to the coolant used in the freezer mechanism. Orange is often a reference to the 'Fast Freeze' function being turned On. Green is showing the freezer unit is at the correct temperature. Red is warning the freezer is Too warm. Some freezers are fitted with an 'Economy' function where the freezer can be run at a lower power level when not used regularly such as when on holiday.
8/2/2022 5:09:29 PM • Hotpoint... • Answered on Aug 02, 2022
2answers
My Hotpoint fridgefreezer is freezing way below the recommended temp what cqn I do??
Inside the fridge is a adjusting knob.
1/27/2019 8:31:03 PM • Hotpoint... • Answered on Jan 27, 2019
What is the a2 error code on a hotpoint fridge / freezer?
A2 error Hotpoint fridge what is it mean I want to do
1/26/2019 7:38:51 PM • Hotpoint... • Answered on Jan 26, 2019
My hotpoint ff187 fridge/freezer is making a
clean the door rubbers and sides this sometimes fixes the problem as the seals are not closing properly and the fridge freezer thinks you have left the door open.
2/9/2018 10:41:03 AM • Hotpoint... • Answered on Feb 09, 2018
My FFA70 fridge/freezer is causing my circuit
kevinmdoyle... Hello and welcome to FIXYA, Yours is a UK model... so I (usa) can't help you on SPARES (motor start capacitor) ... however Circuit breakers do go bad...!! (easiest & cheapest to check first) MUCH Easier to test the idea than you would imagine: - Shut OFF your main breaker. - Open your panel & swap the wire with an EQUAL breaker - Tag the wires (to restore when finished trouble shooting) - Restore the main breaker (wait & see)... and don't forget to clean that CONDENSOR per owner manual instructions. If the failure persists... RESORE the BREAKERS. and HOPE it is the START CAPACITOR on your compressor. Carnac the Magnificent
1/15/2018 3:11:44 PM • Hotpoint... • Answered on Jan 15, 2018
Why is my hotpoint upright freezer making a loud pulsating noise
Hotpoint is made by GE so it may break down soon. I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
12/17/2017 4:29:44 PM • Hotpoint... • Answered on Dec 17, 2017
I'va also got a hotpoint ffa70p fridge freezer
I would check the thermostat, and check for loss of gas.
12/3/2017 7:26:12 AM • Hotpoint... • Answered on Dec 03, 2017
I have a Hotpoint FF200E which has started to
Sounds like a stopped up defrost drain.
11/10/2017 1:54:44 PM • Hotpoint... • Answered on Nov 10, 2017
Hi , i have a hotpoint quadrio fridge freezer
Check with Hotpoint / GE and inform them of your concerns.
11/7/2017 1:10:46 AM • Hotpoint... • Answered on Nov 07, 2017
Why is my hotpoint upright freezer making a loud pulsating noise?
Check to see if the condenser coil needs to be cleaned. And make sure the condenser fan is running Always disconnect power before attempting to repair any electrical appliance
10/23/2017 12:09:41 PM • Hotpoint... • Answered on Oct 23, 2017
My Hotpoint freezer FZ150 red light keeps flashing. I turn freezer off then on again and its ok for a bit, then it flashes red again,
the flashing maybe door is not sealing check gaskets on door for folds or tears or door not aligned right
3/2/2017 6:21:01 PM • Hotpoint... • Answered on Mar 02, 2017
Hotpoint 3.5 cu. ft. / 99 liter Upright Freezer RZA30 Logo
Popular Tags
11 questions posted
Top Hotpoint Freezers Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Stan Ford
Are you a Hotpoint Freezer Expert? Answer questions, earn points and help others
View Most Popular
Hotpoint Freezers
  • Hotpoint Freezers
Most Popular Question
rza30 freezer thats not freezing
  • Freezers
