20 Most Recent
Sony Handycam CCD-TRV107E Camcorder Questions & Answers
How to transfer the video
You have to have a cable to go from your Camera to your Computer. The computer side will undoubtedly be USB. The camera side will probably mini USB - but could be different based on the camera.
You might need some drivers on your Computer so that it recognizes the external device (camera). If your lucky - it will "find it" on it's own.
The cable you need probably did not come with your camera - as manufacturers have become increasingly cheap. See picture of Mini-USB Cable.
Another option is popping out the memory card and either inserting it into the memory card port on your computer (alot of laptops have them) or getting an adapter (Memory Card to USB) - see picture. Size of adapter will depend on the memory card.
How can i transfer videos from my sony ccd-trv107e handycam to my computer
Not sure, but I always disregard the manufacturer's software and instructions, and just connect a usb cable (if there is a way to do that) and then on your computer the storage of the camera comes up as a hard drive.
Whatever format the videos are in, those are your originals, but you can use ffmpeg (a great command line tool) to change them to any format you like, as the video format of some cameras may not play in things like windows media player, or other players that use old codecs.
If you don't want to convert your videos, you would probably find that whatever format they are in they will play in vlc which is free and open source, as an alternative.
I have HANDYCAM sony CCD-TRV96,I
please help.... i have sony handy cam ccd-trv96. but its a japanese version i need an english version pls help me i cannot set-up the date and time. pls. help me......send me to my email add
[email protected] thank you very much.......and god bless
SONY TRV22E - BLANK LCD and cant see through viewfinder
I called Sony support center in Sweden (my home country). They told me that it's probably a failure in CCD-ship. In such a case, Sony takes the fully responsibility and will repair it without any fee. You only need to pay for one way mail transport.
Tobias Rundgren
Karlshamn
Cannot playback hi8 ccd trv107e pal
Dirty video head! Playback newly opened blank tape for
five minutes, after that eject, reinsert, playback
then eject again five times, these will serve as your
video head cleaner, never use "video head cleaning
cassette tape" for it will only damage your camera.
Most camera has built in video head cleaner
installed inside and activates only when you insert,
initial play/rec, and ejects a tape. If the problem is
still there you need pro fix then.[:0)
I have a video on cassette that I would like to
hi keithcharles,
good day!http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man..kindly type your email and a capcha number and download the manual..you can see the instructions here.
regards,
mastergani
How to capture video from
You can get videos from this camera, or any analog video source, into a computer. You just have to play them into an analog video interface port. These are available as expansion slot cards for a PC. They will come with software to digitise the video input and record it to a file. You don't need any "driver" related to the camera, it is just a video signal source. The connecting leads will be standard RCA signal plugs, like the ones you use to connect to a TV or VHS recorder. You probably already have a lead for this.
Hie i have a sony ccd camera during the day it
I had one of these cameras myself, and yes in low-light it goes onto inferred and indeed this will be black and white, however if you but a lamp from a camera shop that pushes onto the Hot Shoe on top of camera the light will let you shoot in colore in dark conditions.
How do i fix the pixel on my handycam
If a pixel is missing in your imager you have to replace the imager with the ccd board, 2 parts you have to order and solder in . If a pixel is missing on your flip out display you will have to replace the lcd panel. You will not need your solder gun on this repair. just a small philips driver. take your time. the ccd job will not about 30 bucks cheaper than the lcd job which is roughly $100 or so in parts. Get them at andrews electronics. Larry's Electronics. 916-362-8708
[email protected]
