20 Most Recent
Sony Handycam DCR-TRV350 Digital Camcorder Questions & Answers
How can I convert my 8mm tapes to a digital format
If you have DVD Recorder then hook your Video-8 camera in analog AV input and burn a DVD, this will convert analog video/ audio signal of camcorder in digital format and transfer the data on DVD as well. Put that dvd in computer and save it in computer.
How can i record in vcr
On the power switch. Does it say camera/ player or Camera vtr. If it says player you can not record in vcr as you put it. In the earily days when camcorders were $800 and over ,they all Recorded from line in in the vtr mode. Not any more . See you you can switch to line in mode in the vtr postion however. Larry's Electronics 916-362-8708
E:61:10, can I fix it myself?
the problem of your camera is the lens assembly.... one of the lens motor is not running or stuck up...try to remove the connection of the lens assembly and back it again...
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock" Good luck
Troubleshooting
Same happend to mine I pressed on cassette cover while pressing eject tokk a few times but it worked
