20 Most Recent LG Studioworks 563N 15" CRT Monitor Questions & Answers
I have just plugged my screen into a new tower
Have you tried another monitor to see if the computer is working?
2/10/2018 12:34:26 AM • LG Studioworks... • Answered on Feb 10, 2018
Lg monitor power problem
Here's some tricks I would try. Something here, might help... 1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor. 2. Verify the monitor cable is firmly connected to the computer and the monitor. 3. Verify that you have turned the monitor power switch on. 4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works). 5. If the power light on the monitor is not on, try a different power cord. 6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced. 7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers. Good luck.
8/7/2014 11:12:13 PM • LG Studioworks... • Answered on Aug 07, 2014
Monitor Reset Problem
Id try a different monitor to start with. What program are you using when it blanks out?
2/24/2014 10:15:50 PM • LG Studioworks... • Answered on Feb 24, 2014
0answers
Power led turns green when switched on but after 1or 2 sec it trips it happens again & again display does not come
Make sure that all of your cables are plugged in properly. Sounds stupid but I suggest unplugging every cable you can see, plug them back in firmly and try again. Also make sure that there are no USB's plugged in, or discs in the disc drive as your computer may be attempting to boot from these and failing.
11/30/2013 11:37:47 PM • LG Studioworks... • Answered on Nov 30, 2013
0answers
Service manual
Be the first to answer 11/30/2013 12:30:02 PM • LG Studioworks... • Posted on Nov 30, 2013Be the first to answer
I Have 15" LG monitor when i start the power the
Posibile the flyback is spoilt. It is not worth to fix it since it is aging. Buy a new one.
10/30/2013 4:55:01 PM • LG Studioworks... • Answered on Oct 30, 2013
2answers
Power is on but self display & cpu display not
probably itz either minor case of improper ground/cpu fan/faulty power cable..
or major case of faulty or defective main board/ram/daughter or addon card(s)..
..plz do check the following as in order:..
the Hardware part:..
1)a)in power on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd'or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4)see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6)remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7)open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8)on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
if u r not a professional, always better to seek advise from ur system admin/vendor....
7/19/2013 7:36:52 AM • LG Studioworks... • Answered on Jul 19, 2013
Monitor blinks when power is turned on
shoot it with a shot gun. get a new one.
5/9/2013 6:13:29 AM • LG Studioworks... • Answered on May 09, 2013
No power into my crt monitor samsung
first disconnect the path of EHT then check voltages if present then open H o/p transistor check it if faulty then replace it if not then EHT is faulty replace it also check IRF630 mosfet if faulty replace it
4/25/2013 5:41:47 AM • LG Studioworks... • Answered on Apr 25, 2013
2answers
Out of frequency error for monitor
manage your frequency upto 60 Hz.....
and do not interfere with graphic properties
3/2/2013 4:14:33 PM • LG Studioworks... • Answered on Mar 02, 2013
3answers
Power is on(green) but no picture or (no signal)
may be the problem with the output transistor
11/2/2011 6:16:33 PM • LG Studioworks... • Answered on Nov 02, 2011
LG studiowork 563N desktop bottom
Hi, It could be you need a new V-card. or your monitor is on its way out. My bets are on the monitor. Good luck.
9/15/2011 3:28:16 AM • LG Studioworks... • Answered on Sep 15, 2011
LG Studioworks 563N 15" CRT Monitor Logo
102 questions posted
Top LG Computers & Internet Experts
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Studioworks LG
  • Studioworks LG
Most Popular Question
lg studiowork 563n desktop bottom
  • Computers & Internet
