20 Most Recent
Hotpoint FFU00 Side by Side Refrigerator Questions & Answers
Supply pipe to icemaker split
if tubing cracked replace. you can use the push on type connector for this repair. all avail at any lowes or home depot. (unless its the 5/16 size line then its appliance parts only)
Ice maker dispenser door
you need an ice duct door spring and selenoid call ge at 800-851-6200 about 40 dollars for parts they go in the freezer door despenser area
Ice maker not working
What's the temp. in the freezer? Should be below +10F, otherwise you have a bad ice maker most likely.
Freezer has a wering sound on and on
This problem can range from a variety of things.Defrost control, defrost element/thermostat, defective fan motors, defective start relays and even more. The refrigerator should cycle into defrost every 8 to 10 hours. The fact that yours is making a noise and then stopping every 5 hours makes me think that you either have a defective fan motor condenser or evaporator or a defective start relay. Now if the freezer shows signs of frosting over this will change the whole solution. Give me more information on where and what sounds are coming from. Clean the condenser coil beneath the fridge. and examine the fan and see if top of compressor is too hot to touch, Let me know, Sea Breeze
