20 Most Recent Bravetti Quad Blade Food Processor Questions & Answers
3answers
Bravetti Food Processor Model KP80B
That's alot of bad outlets.Are you sure there's nothing wrong withe the processor? Just kidding. How long have you had this processor? Any chance of taking it back?
If not, try this. With the unit unpluggedput an attachment on that you can hold onto and try to rotate the motor. Not all are tested and sometimes the motor brushes are not making good contact. If you turn it manually you may get lucky and set them to work. If you get it running, chk with power after several turns, run it constantly for abot 5 minutes to seat the the brushes. Remember to have it unplugged when you have your hand on the attach ment. Good luck. Ned
1/31/2015 11:03:04 PM • Bravetti Quad... • Answered on Jan 31, 2015
3answers
Bravetti Food Processer
You can get parts from this company.
http://www.euro-pro.com/europro/productdetail.aspx?pid=E50ADA3D-BACA-44E7-9E78-05263C526241(Euro-Pro+Base+Catalog)
You can call them as well
For technical support, please call us toll-free at 1-800-798-7398. Hours are Monday through Saturday from 9:00am to 6:00pm Eastern Standard Time.
7/3/2013 1:23:42 AM • Bravetti Quad... • Answered on Jul 03, 2013
2answers
Model kp80b
You can see all of the blades and their function in the user manual.
The Bravetti KP80B food processor user manual can be read and saved from this website
http://www.euro-pro.com/europro/manuals/KP80B.pdf
If it's not there let me know and I will send it to you.
Rj
8/5/2012 6:13:44 AM • Bravetti Quad... • Answered on Aug 05, 2012
2answers
Bravetti EP 199
I had the same problem. I noticed that the bowl has to be on and locked in for anything to work. THE MAIN issue though is that the piece from the lid slides in to turn an actuator. well it doesn't turn it far enough to engage it. so all you have to do is add something to the turning actuator to give it that extra 5 degrees to turn on. This is not an official fix. Just a quick fix. I will be leaving it there forever. So the problem is not power or anything electrical. it is the mechanical turning of that piece that is the culprit.1_15_2012_4_55_38_pm.jpg1_15_2012_4_56_01_pm.jpg1_15_2012_4_58_09_pm.jpg
1/15/2012 5:02:40 PM • Bravetti Quad... • Answered on Jan 15, 2012
2answers
Replace processing glass jar for bravetti quad blade food process
type bravetti in search bar. There might be something you can use in your quest.
8/4/2011 2:30:03 PM • Bravetti Quad... • Answered on Aug 04, 2011
I have the Bravetti Food Processor-Model # KP80B.
I went to my manuals sites and they did not list this brand.
the internet indicated the problem with this food processor was the inability to obtain parts.
I advise keeping an eye on ebay if you need something in particular.
(if this has been helpful, please give me positive feedback)
8/18/2010 11:15:59 AM • Bravetti Quad... • Answered on Aug 18, 2010
The blade folder for Bravetti food processor broke
I hate to give bad news. But the report on this processor is that one can not obtain replacement parts.
8/18/2010 11:02:08 AM • Bravetti Quad... • Answered on Aug 18, 2010
It will not turn on - just bought this as a new
caveat emptor
there is usually a cooling off period on these types of sales. return it! most estate sales suggest testing before bidding or give statemnt that it has been checked. contact selling agent
Please rate my help++++Thanks for using FIXYA
6/25/2010 4:39:27 AM • Bravetti Quad... • Answered on Jun 25, 2010
I broke the stem to the shredder blade. I need
Here's the link to get parts for the Euro Pro Bravetti products. I hope this helps you!
http://www.euro-pro.com/europro/default.aspx
2/13/2010 1:46:19 AM • Bravetti Quad... • Answered on Feb 13, 2010
Need manual for Bravetti Food
Here you go:
--RescueTechLA
12/2/2009 9:38:58 PM • Bravetti Quad... • Answered on Dec 02, 2009
BravettiQuad Blade 600 watt Food Processor ID 22095926
Try this site, good luck, Ned
overstock.com/Home-Garden/Food-Processors/.../subcat.html
10/30/2009 7:14:16 PM • Bravetti Quad... • Answered on Oct 30, 2009
Food processor
overstock.com/Home-Garden/Food-Processors/.../subcat.html\
Try this site- good luck , ned
10/30/2009 7:12:31 PM • Bravetti Quad... • Answered on Oct 30, 2009
Bravetti Model # EP 545
type bravetti i the search bar. one of the results returned may be your source. Good Luck, Ned
10/30/2009 7:04:26 PM • Bravetti Quad... • Answered on Oct 30, 2009
The top lid has a plastic round piece that connects to a rubber
Doug; Type in Bravetti in the search bar and you can find resources to find the gasket. good luck
10/30/2009 6:45:28 PM • Bravetti Quad... • Answered on Oct 30, 2009
Bravetti Quad Blade 6 Cups
unplug it, then use the blade tool to rotate the motor by hand a few times. Not all are tested and turn it by hand will set the brushes. Plug it in and see what happens If you have to turn it several more times make sure to unplug it.. Good Luck, Ned
10/30/2009 6:43:30 PM • Bravetti Quad... • Answered on Oct 30, 2009
Not coming on
Does it have a switch that doesn't work? Unplug it and use the blade tool to rotate the whole motor . Turn it several times. Not all are tested and sometimes the brushes aren't seeated. Rotate in direction of normal rotation. Several rimes. Good Luck _Ned_
10/30/2009 6:40:17 PM • Bravetti Quad... • Answered on Oct 30, 2009
Bravetti EP 199 Need Manual
Type in bravetti in search bar and you may get lucky
10/30/2009 6:34:42 PM • Bravetti Quad... • Answered on Oct 30, 2009
To buy a processor bowl
type in bravetti in search bar and you may get lucky.
10/30/2009 6:33:31 PM • Bravetti Quad... • Answered on Oct 30, 2009
Bravetti Quad Blade Food Processor Logo
38 questions posted
Top Bravetti Food Processors Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Bravetti Food Processor Expert? Answer questions, earn points and help others
View Most Popular
  • Bravetti Food Processors
Most Popular Question
blade folder bravetti food processor
  • Food Processors
