20 Most Recent
Sony DVDirect (VRDVC20) DVD±RW Dual Layer Burner Questions & Answers
Burner won't eject disc following
Hello.
Check your burner software program.
If your burner displays in My Computer as a removable drive, Right-click on the drive icon and select Eject, the program you are using must not be set to eject after finalizing the disc in the Preferences or Settings.
If not a software problem, look for a tiny hole near the drawer of the burner With the computer or burner (if external drive) powered off and a paper clip opened, push the end of the paper clip in the hole to release the drive.
How this helps.
Gracias por atenderme,,,por favor si
Por favor, ve a www.sony.es
Ve a la sección de soporte (menú superior izquierda),
en la página de soporte hay un link para todos los manuales de productos sony en español.
http://212.9.75.220/sony-manuales/htm/frm_find_manual.htm
Pones el modelo y ya esta.
Mas adelante pide tus datos, con el nombre y el mail hay suficiente, los otros son opcionales; lo rellenas a tu gusto.
Steelmith
I CANNOT RECORD ON THE
Witout having any more information than you provided at this time, I will provide the following information. SP mode will provide about 2 hours of recording time. Trying to record a larger image than that will cannot be done in SP mode.
The following are the type of disks that are compatible with the recorder: DVD+R single layer, DVD+R DL (Double Layer), DVD-R, DVD+RW and DVD-RW.
Please give me more detail about the type of recording you are doing, be it manual, sync from a Video Device or a Video Camera. If you are using it as a stand along device or with a computer.
Brian
I am getting the message
Just more patience to wait for another moment.If still doesn't work,close the process,then try it again.
I need drivers!
This comes right off the Sony website....
Operating System:
Windows
Date:
04/18/2008
Do you need a Driver? (External models)
All Sony Optical external units are plug & play with Windows,
no drivers are required for detection.
If you are having issues getting your external drive detected in Windows, please try the following:
The drive needs to be connected directly to USB 2.0 or I-link port (depending on model type) on your computer. Please note that the drive is not supported if connected to a dock or a hub.
Also please check the following if you are have trouble detecting:
- The drive needs to be the only external device connected to the system. Please ensure there are no other USB devices connected.
- Try a different USB port on your computer.
- Try a different USB cable
- Try the drive on a second computer system if possible.
- Ensure you have the latest BIOS and Motherboard updates from your PC manufacturer.
- Ensure you have the latest Windows updates from Microsoft.
http://sony.storagesupport.com/node/7183
My vrd-vc20 do'not eject my disk
if your writer is showing in My Computer as a removable drive, you should bea able to right click on the drive icon and select Eject, but the programme you are using to burn must not be set to eject after finalising the disc in the preferences or settings.
No Disc
Check on sony.com for a service center in your area.
