20 Most Recent Magic Chef CMV1000B Microwave Oven Questions & Answers
Theres no power getting to
Pl. check mains supply and the plug of the microwave if every thing o.k check the fuse provided inside the oven,if o.k then the problem in the control panel,check the panel by replacing the same .
3/4/2019 7:53:29 AM • Magic Chef... • Answered on Mar 04, 2019
My MAGIC CHEF MCO153uw stopped working. It heats
This sounds like a thermal protector is turning the microwave off. If I were to hazard a guess, it would be the magnetron (produces the microwaves) is overheating causing the shutdown. If the fan was not running it would create the same condition by causing the magnetron to overheat.
11/15/2017 7:22:40 PM • Magic Chef... • Answered on Nov 15, 2017
My microwave keeps blowing the fuse upon hitting the start button
you have one of three problems (H.V. diode shorted or leaky, H.V.capicitor shorted, or the magnrtron tube is beginning to draw excessive current)if thats the case its not usually worth spending that for the mag.,the other two items aren't that expensive
10/30/2017 9:19:46 PM • Magic Chef... • Answered on Oct 30, 2017
My cooling fan will not
There are typically 2 fans in these units. The fan that cools the magnetron and then the vent fan that intakes from the top of your stove then vents the air out or away from the unit. Are the lights that shine on the top of the stove working?? Sometimes if a bulb blows violently it can blow a trace off of the back of the main circuit board and that trace may also supply power to the fan
10/26/2017 9:06:04 PM • Magic Chef... • Answered on Oct 26, 2017
Microwave acts posesed. The Microwavve
take it to an appliance repair shop for a proper diagnosis and quote
7/6/2017 9:10:49 PM • Magic Chef... • Answered on Jul 06, 2017
2answers
I have had my Magic
Sounds like it is ready for the dump!
Without anymore information and diagnostics, it is not possible to diagnose further.
5/9/2017 12:49:38 PM • Magic Chef... • Answered on May 09, 2017
2answers
Shut's off after cooking popcorn, only popcorn,
Sounds like the magnetron is over heating. Try putting a 4 0z cup of water in the oven along side the popcorn bag. See if this helps. Usually, the oven only runs 2 to 2.5 minutes for a bag of popcorn. You may have to experiment with the slightly different cooking time...
5/18/2016 12:28:24 AM • Magic Chef... • Answered on May 18, 2016
I dont know how to
For more help from Magic Chef / Ewave see here or their contact page or order parts here.
For Magic Chef in Canada call 866.587.2002
11/24/2015 5:09:39 PM • Magic Chef... • Answered on Nov 24, 2015
Replace light bulb.
http://www.ehow.com/how_7614605_replace-chef-microwave-light-bulb.html Here is one link that i've found. It didn't mentioned the exact model but i hope this one helps...
3/7/2015 5:33:20 PM • Magic Chef... • Answered on Mar 07, 2015
Microwave still runs but is not cooking food
Sounds like a bad magnetron, i would replace the magnetron, Capacitor and Diode at the mag assembly, to be honest it will cost you more to fix than a new one.............
1/4/2015 6:34:34 PM • Magic Chef... • Answered on Jan 04, 2015
2answers
My microwave lost all power.
The plug should be located in the small cabinet above the stove. Leave it unpluged at least for 10 minutes. Mine does it occasionally when it gets hot. I haven't had a problem since I turn the fan on when I run it.
7/7/2014 7:00:38 PM • Magic Chef... • Answered on Jul 07, 2014
Appliance will not heat,but operates
The problem is in the magnetron the heart of the system, or the inverter board, if microwave oven is 7 years old or less.
6/5/2014 9:23:23 PM • Magic Chef... • Answered on Jun 05, 2014
3answers
Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
5/29/2014 6:16:26 PM • Magic Chef... • Answered on May 29, 2014
3answers
Lost total power of microwave
check fuses
5/9/2014 5:15:53 PM • Magic Chef... • Answered on May 09, 2014
Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
4/8/2014 2:44:35 AM • Magic Chef... • Answered on Apr 08, 2014
2answers
Magic chef over-the-range microwave shut off
I have a Magic Chef Microwave Model MC0153UB that is shutting itself off while cooking. I noticed before this, the light under the microwave blew during a storm. Do you have any suggestions?
3/27/2014 10:58:28 PM • Magic Chef... • Answered on Mar 27, 2014
Magic Chef CMV1000B Microwave Oven Logo
222 questions posted
Top Magic Chef Microwave Ovens Experts
Jerry Naidoo
NOEL
NOEL
vince
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
View Most Popular
  • Magic Chef Microwave Ovens
Most Popular Question
lost total power microwave
  • Microwave Ovens
