20 Most Recent Sony Play Station 3 System Backpack For Ps3 Questions & Answers
It's flashing for one of two reasons. It is either about to die because the batteries need to be charged. Or it is hooked up and charging. Those are the only two reasons I can think of for them to flash. Possibly not connecting, but you would have probably said that if it was the case.
Sony Play... | Answered on May 13, 2016
Try turning off the PS3 at the back and then on again after about 15 - 20 seconds. When you turn it on, press the eject button.
Sony Play... | Answered on Jan 02, 2016
Turn off at the mains and on again. Hold down the standby button until you hear a series of beeps to do a hard reset.
It may be worth trying to uninstsll and reinstall your downloaded games or checking for updates.
Sony Play... | Answered on Dec 21, 2014
1 To reset your PS3 back to its original settings go to options. Select system settings and click reset system. WARNINGFollowing these directions will wipe ALL data from your PS3 system. Do NOT do this,
(this will reformat the HDD)
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
3 After you complete the operation and restart the system, the initial setup screen will be displayed. Follow the on-screen instructions to perform initial setup of the system software. Note that performing hard reset on your PS3 will return your password to 0000. However, note that all settings other than the password will also be reset. Once these settings are reset, they cannot be recovered.
Sony Play... | Answered on Nov 25, 2013
Most likely, your drive is not working and needs to be replaced.
Sony Play... | Answered on Nov 06, 2013
That is a sometimes common problem on the Netflix server's end. The best work around only works about half of the time and that would be to exit the movie or show and find a series with multiple episodes and start an episode for a minute or two, then go back to the show you were wanting originaly.
This causes the session cach on the server end to remove the old data for the new show, so the one you wanted originally will be forced to attempt reloading.
Sony Play... | Answered on Oct 15, 2013
Editing two simple operating system settings can solve this connectivity problem.
Sony Video Game... | Answered on Feb 13, 2020
It's the multitap, yours is designed for PS1 games, and PS2 and PS1 games require different multitaps. You have to buy one specifically for PS2.
Sony Video Game... | Answered on Jul 27, 2019
its probly the game disc mate. its had its day. u can send them to shops that fix disc 4 u, 4 a cetain price. if it still dont work then only option is to by new fifa games.
Sony Video Game... | Answered on Jun 13, 2019
First you will need a pin out of the adapter.
Tools you will need are.
1: Solder with rosin core thin solder would be best 2: Soldering iron lower watts the better 3: Flux to clean the surface you want to solder to 4: Sponge to clean the tip of solder iron If you don't have any of thous supply's it would be cheaper to buy a new cord. Also if you don't have vary much experience soldering i would also recommend getting a new cord for the fact you can cause more damage than good.
To get the solder iron ready you need to heat it up. Once it is hot enough to melt the solder apply the solder to the tip and let is set there until you want to solder. You have to clean the tip off with a wet sponge but not soaked in water just enough to get it wet. Every time you go to solder Clean the tip off and apply fresh solder to it not a lot just enough to cover the tip when you want to solder. When you go to store the iron apply a small blob of solder to the tip to keep it from oxidizing.
Strip the wire shielding off a bit longer than the size of the contact you want to solder. Twist the wire and put flux on the surface you want to solder and tin them.
Tinning the wire is just applying a small amount of solder to the wire as to hold the strands together and make it easier to transfer the heat and solder to the contacts. Now mach the pin-out to the weirs to the contacts and put flux on the contact you want to solder to. Clean the surface by applying flux to it.The surface will be oxidized and will not let you transfer heat or solder to the surface. The key to soldering is to use the right amount of heat , solder and time you hold the iron to what your soldering to. You want to make sure you touch the wire and the contact you are soldering to as to transfer the heat to both items at the same time to make the solder flow. Put the solder wire to the tip of iron that is touching the wire and contact and not on top of the iron tip. Any time you apply heat to solder joints you want to use flux to keep them clean and free of oxidized material. After you solder check the solder joints for cracks, uneven and dull surface. You want the solder to look as shiny as possible and smooth. If it looks like it has waves or holes and cracks it means you have a cold solder joint and must reheat and apply flux with a small amount of solder to fix it .Here is a link to help you out this is not my site and full credit goes to the owner of site. How To Solder Soldering Tutorial Also put a link to a new cord if you decide you want to get a new one. Here is a link that may or may not help with the pin-out. Also not mine it should credit the poster on the forum as he did all the work i just found it PSP Go Cradle mini USB Tutorial with Partial Pinout PSP Go Acidmods com
Sony Video Game... | Answered on May 28, 2019
may be you need cdkeys for the game, or your consoles do not work, you need find what prolem actually is, if need cd keys you can have a view on https://www.m8x.com, if your console do not work, you should repair it, if you need FIFA Coins, FUT Coins or FIFA 19 Coins, you can have a view on https://www.fifacoin.com
Sony Video Game... | Answered on Feb 21, 2019
Sony Play Station 3 System Backpack For Ps3 Logo
13 questions posted
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Nikki  Mclean
Nikki Mclean
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Video Game Consoles & Games
Most Popular Question
netflex com support
  • Video Game Consoles & Games
