20 Most Recent
Miele W1903A Front Load Washer Questions & Answers
Washer won't agitate
I would start by checking the belt on the motor could be slipping when u put full load in washer. also check that pulleys are not loose.
Hi there, my Miele W
Please ensure you have used the proper procedure on page 26 of the manual for cleaning the lint trap.
MANUAL -
LINKUnplug the unit for 20 minutes if turning the Dial back to Start/Finish does not reset the lamp.
Thanks!!
Miele W1926 check inlet light flashes
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
