20 Most Recent Miele W1926A Front Load Washer Questions & Answers
3answers
How do I fix a F53 fault ona Miele W1712 Washing
A call with the Miele tech helpdesk got me an answer: The tacho unit (coil) should have about 500 Ohm resistance, so they told me. My unit only had about 78 Ohm's, so I ordered a new brush unit (which includes the tacho). The new unit actually measures 250 Ohm, but since it was a new one I did fit it. It works like a charm again. No F53 fault code anymore. The part no. is 6799642 - Module BSTV Mrt40 RK473. It cost me about 70 euro's including shipping. My machine is a type W3821, but the motor and brush unit with tacho is used on a variaty of models. Cheers!
10/11/2020 7:23:40 PM • Miele W1926A... • Answered on Oct 11, 2020
Miele W1926 Door Won't Open
You probably still have something stuck in the filter in have had the same problem and found it to be the remnants of hair scrunchie.good luck
7/5/2016 12:35:26 AM • Miele W1926A... • Answered on Jul 05, 2016
I cleaned the lint trap and now water flows out of the drain tube when ever a wash is started. What did I do?
sounds like the rubber washer came off & you didn't spot it, look for the washer on the bit you take out if it hasn't got 1, it should have.
5/9/2015 8:49:08 PM • Miele W1926A... • Answered on May 09, 2015
Miele W1926. The red light over the faucet icon is on at the end of the cycle and the final spin cycle doesn't go on.
Check the screen filter where the cold water line attaches to the machine. Clean both hot and cold.
5/3/2015 8:56:28 PM • Miele W1926A... • Answered on May 03, 2015
How to put top back on miele w1926
1 Remove stacking kit from top of unit. 2 Reatach the two plastic clips to the back of washer. 3 engage the two slots on the washer top into the clips , pull forward drop lid down on top of washer then secure with two screws on either side of lid.
1/29/2014 3:56:00 AM • Miele W1926A... • Answered on Jan 29, 2014
0answers
Miele W1926 burning smell
The front support seals -felt around the top of the door -are worn out. You can order them online with your model # or call the parts distributor and tell them you need the replacement kit - it comes with the top and side seals. To get them separate is more money. You will have to take apart the front of the unit - top first - then the control panel and then the door (front). It supports the drum. You will need to scrape off the old seals and apply the heat glue for the seals. Put the new seals on and reassemble the unit. This should do it if it was rubbing on the front plastic.
1/10/2014 1:30:19 PM • Miele W1926A... • Answered on Jan 10, 2014
0answers
W1926
Be the first to answer 4/23/2013 6:07:59 AM • Miele W1926A... • Posted on Apr 23, 2013Be the first to answer
0answers
0answers
W1926
Be the first to answer 1/14/2013 5:45:20 AM • Miele W1926A... • Posted on Jan 14, 2013Be the first to answer
0answers
0answers
2answers
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
1/21/2012 5:33:25 PM • Miele W1926A... • Answered on Jan 21, 2012
Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
12/1/2011 4:45:49 PM • Miele W1926A... • Answered on Dec 01, 2011
Our 1926A wont take the
I suspect that it is the conditioner/softener tray which needs a thorough clean,
paying particular attention to the sentences in BOLD ;-0)
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
One of these should enable you remove it
(I am having to guess some of the following!)
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this does not work, pull out the dispenser drawer far enough to be able to just see the softener tray, select the (final?) rinse and check that water is entering the tray. If it isn't there is a fault with the water distribution and an engineer call is required ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
5/10/2011 7:24:43 PM • Miele W1926A... • Answered on May 10, 2011
Miele W1926A Front Load Washer Logo
42 questions posted
Top Miele Washing Machines Experts
Paul Carew
vince
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Miele Washing Machines
Most Popular Question
fix f53 fault ona miele w1712 washing
  • Washing Machines
