20 Most Recent
Miele Touchtronic W1213 Front Load Washer Questions & Answers
Miele W1213 intake, drain and 3 - - - faults
Have had this since 2007 or 2008. Pain in the backside.
Fixed it by:
Cleaning drain.
Unplugging from power.
Tilting forward to drain water for 1-2 mins.
Made sure that the clear plastic light ***** in the rubber opening which located at the top was tight as it tends to get loose if you have an off-balance load.
Plugged power back in.
Boom, she started up.
This is a great washer/dryer, but it's expensive to fix if you need a repairman and it's a bit of voodoo if you need to do the above.
HTH
4/8/2016 3:49:26 PM •
Miele...
Answered
on Apr 08, 2016
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
9/26/2015 10:04:27 AM •
Miele...
Answered
on Sep 26, 2015
