20 Most Recent
Echo Chain Saw Service Repair Manual Cs-315 Gas Saw Kioritz Corp Questions & Answers
How to change the fuel filter on an Echo 315
Im going to assume that this echo saw is the same as most saws.
Open your fuel tank and remove the cap completely.
Empty the fuel from the tank, and try to swirl around the fuel to get the last bit out and any dirt that might be in the tank.
Compressed air can be used to blow the tank out or flush the tank with some more fresh fuel. This is important to help your new fuel filter last longer and also the reason why the filter would need replacing.
Using a length of wire, coat hanger or smaller, make a small hook on the end, small enough to get into the fuel tank, big enough to fit around the fuel line. Place the hook in the fuel tank and fish out the fuel line and the gently remove the filter from the tank, its on the end of the fuel line.
Pull the old filter off and push the new filter on,
Place back in the tank,
Fit the fuel cap chain and fuel cap.
Job done.
Hope this helps
Weedeater want reb up put new carburator 230 echo weedeater
I know this is a very old post, but figured I'd answer it so any others with this issue can have the fix.
With Echo trimmers not revving to speed although they start with no problem, the issue is usually the muffler screen. It becomes plugged with carbon because of improperly mixed 2 stroke fuel.
Remove the screen from the muffler and burn off the carbon with a propane torch, or wire brush it off. Once cleaned engine should rev to speed.
6/25/2022 4:53:50 PM •
Echo Garden
Answered
on Jun 25, 2022
