20 Most Recent
Westinghouse 1935 Streamline Refrigerators Advertisement Questions & Answers
Westinghouse side by side refrigerator, model WSE6100WA fridge not working and electronic display is blank,
If the electronic display is blank and the fridge is not working, it is possible that there is an issue with the power supply to the fridge or with the control board. Here are some steps that you can take to troubleshoot the issue:
- Check the power supply: Make sure that the fridge is properly plugged in and that the circuit breaker hasn't tripped.
- Check the control board: The control board is responsible for regulating the temperature in the fridge and freezer. If the control board is faulty, it may cause the electronic display to be blank and the fridge to stop working. Try resetting the control board by unplugging the fridge for a few minutes and plugging it back in.
- Check the temperature sensors: The temperature sensors in the fridge and freezer are responsible for communicating the temperature to the control board. If a sensor is faulty, it may cause the fridge to stop working. You may need to replace the faulty sensor.
- Call a professional: If you're not comfortable troubleshooting the issue on your own, it's best to call a professional appliance repair technician to diagnose and fix the problem.
It's important to address this issue as soon as possible to prevent food from spoiling in the fridge and freezer.
The alarm on my westinghouse WSE6100WA side by
Hi I have this same problem. The seals are all fine. I tried taking the back panel off the freezer. There was a little bit of ice there but not much. I defrosted it as suggested here. I also cleaned the coils on the back. Things will freeze, but it never gets to the desired -14 degrees Celsius, so it beeps regularly.
Westinghouse wse6100sa side by side fridge. Freezer not cold enough
Check to see that the fridge is level and the doors are properly aligned and closing properly.
If the door hinges are not set properly, the door will not close properly and there will be an air leak around the seals.
If this happens, the fridge will run continuously and all the stuff in your vegetable bin will keep freezing
If
Westinghouse WSE6100WF Evap coils frosting up.
Have you verified the evaporator coils aren't clogged up? If no airflow can get through the evap coils it can cause freezing.Edit.The defrost timer is usually in the toe kick area. You should be able to put a flathead screwdriver in it and turn it clockwise slowly until you hear 1 click- that is in defrost. Verify the heating elements are warming.
