20 Most Recent Westinghouse Top Freezer 18.2 Cubic Foot Total Capacity Refrigerator Questions & Answers
Your problem is one or more parts of the defrost system is malfunctioned and in return your problem arises. There are three parts to the system, the defrost timer or in some cases control board, defrost thermostat also known as a bi-metal, and the defrost heater. The defrost system is set up to operate as so. The defrost timer or control board will turn the machine off, in some cases every 8 hours, some 12. During this time period the defrost heaters, located behind the freezer wall and rest underneath the evaporator, yet wires to them run up the side of it, are energized and emit heat that raises upward to melt the ice that has formed on the evaporator coils. The bi-metal or defrost thermostat is at the top of the evaporator. When the heat from the heater starts to reach the bi-metal, it breaks the circuit turning the heater off. The whole purpose of this is because the freezer cool the refridgerator side by drawing air across the coils and blowing to the other side via the evap fan motor. In my opinion, if you change one part of the defrost system change them all because usually when one part fails another will follow, so save yourself the time and the food loss, the cost difference is minute.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Westinghouse Top... | Answered on Apr 30, 2012
that will be the defrost heater being on . possibly the timer is stuck in the on position , call a local repair shop for assistance
Westinghouse... | Answered on Dec 19, 2019
Most likely there’s a spring broken inside the compressor. When it shuts off the internal mechanism is bouncing around. The only way to fix that is by replacing the compressor.
Westinghouse... | Answered on Oct 01, 2019
Fridge/freezer freezing up- and no fan or air circulation:
first check the defrost terminator thermostat it may have gone out. Thus not allowing the heating element to melt the ice.
AT TIMES The fan usually stops working AND CAN MAKE FUNNY NOISES AS WELL due to ice obstruction when the defrost terminator has gone out and u get ice build up? u can check the terminator with a multi meter for continuity but do not check at room temperature. stick the terminator in cup of ice water for 20 minutes then check it for continuity, should be closed when cold and open at room temperature.
May also need to check the defrost timer, The defrost timer is usually found behind the front grill "toe kick" of the refrigerator. Or in the fridge compartment near middle top section.
u can get by and test manually by placing a small screw driver into the tiny slot or hole underneath the timer and turn slowly clockwise till u hear 1 click. this will engage ur defrost cycle in about 15 minutes u should be able to come back and feel the heat in freezer as it melts the ice providing ur terminator is not bad?
Another way to test it is with a multi meter. Remove timer it from fridge and you will see 4 prongs numbered 2,1,4,3 in that order. Place ur meter prong on prong 1 & 3 (if your fridge has a capacitor wired in series with the windings, then u check for micro fares rather than OHMS) If u cannot confirm this test, still try the next.
Take ur meter prong and connect to prong 1 & 4, it should read resistance or ohms ( closed) now remove prongs and place on prong 1 & 2, this should now read infinity or open (no ohms) now take a small screwdriver place it in the tiny hole or slot under the timer. Turn it clockwise slowly till u hear 1 click. Now ur 1& 2 should read closed ( showing ohms or resistance) now place meter prongs on 1 & 4 and you it should now show open ( or no resistance - no ohms) this is how u know ur timer is good, Remember when testing for ohms ADJUST meter to use a high ohms rating in the thousands as the resistance is very high in OHMS. And adjusting to low ohms rating may give a false reading or not show the proper resistance..
Another item to check with a meter is the heating element itself. Located under the evaporator coils. It should show continuity or resistance OHMS WHEN TESTED AT BOTH ENDS OF THE PRONGS .
Lastly check the cold control thermostat with a meter for both OHMS and volts ( VOLTS is a live test with fridge plugged in so be careful) It must show 110 volts. An open or thermostat that reads infinity will not allow the proper cooling and defrosting cycles to operate and may in fact stop anything from happening as if there is no power to the unit?
ALSO CHECK THE AIR FLOW VENT SYSTEM and THERMISTORS At times it can get stuck to far closed or open. Some units feature a digital electric adjusting vent system while others are manually set. Check for any ice build up or other obstruction in the vent damper, see if u can manually open or close it. Some times when u have the settings set to the highest it closes off one area while allowing to much cold air flow to the other area!
THERMISTORS in the freezer and fridge section for continuity OHMS and for amount of OHMS current being put out. In most models around 1300 ( give or take 150 ohms) ohms is required
Fridge Warm Defrost Thermostat Testing Troubleshooting Refrigerator Repair Frosting up in freezer not cooling Admiral RSCA207AAM Kenmore Whirlpool refrigerator frost build up in freezer not cooling...
Westinghouse... | Answered on May 23, 2019
Usually because the defrost drain gulley in the rear of the cabinet is blocked.
Westinghouse... | Answered on Mar 09, 2019
There is no default setting , the temperature is set by you , check the user manual on how to do this.
Westinghouse... | Answered on Jan 27, 2019
Westinghouse Top Freezer 18.2 Cubic Foot Total Capacity Refrigerator Logo
8 questions posted
Top Westinghouse Refrigerators Experts
John Tripp
John Tripp
Ekse
Vincent G
Vincent G
Are you a Westinghouse Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Westinghouse Refrigerators
Most Popular Question
freezer working but refrigerator will
  • Refrigerators
