20 Most Recent
Echo Pb-2100 Pb 2100 Leaf Blower Fuel Gas Tank & Cap Questions & Answers
How do i check spark on my echo leaf blower
You can take a spark plug tester and plug one end into the spark plug wire and the place the other end on the spark plug and pull the starter rope and see if there is a spark present. Hope this helps.
Weedeater want reb up put new carburator 230 echo weedeater
I know this is a very old post, but figured I'd answer it so any others with this issue can have the fix.
With Echo trimmers not revving to speed although they start with no problem, the issue is usually the muffler screen. It becomes plugged with carbon because of improperly mixed 2 stroke fuel.
Remove the screen from the muffler and burn off the carbon with a propane torch, or wire brush it off. Once cleaned engine should rev to speed.
6/25/2022 4:53:50 PM •
Echo Garden
Answered
on Jun 25, 2022
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at
PartsBuggy.com.
5/6/2021 5:12:27 AM •
Echo Garden
Answered
on May 06, 2021
