20 Most Recent Ryobi Rht-2660DA Quik Fire Hedge Trimmer 26Cc Questions & Answers
The spark arrester is built into the muffler.
Ryobi Rht-2660DA... | Answered on Mar 06, 2015
NO....... YOU WILL NOT USE THIS
But you will use maybe this a bearing separator .
Ryobi Garden | Answered on Dec 04, 2019
Hi Jeffrey-
I found a youtube video regarding troubleshooting a generator with no spark.
https://www.youtube.com/watch?v=Wi5gTyyHUIU
Hope this helps.
I also found a link for the Ryobi Ryi 2300BT Owners Manual.
https://manuals.ttigroupna.com/system/files/9994/original/RYi2300BT_BTA_090930309_330_506_trilingual_05.pdf?2019
Ryobi Garden | Answered on Nov 28, 2019
Go to ryobi website and get a user manual
Ryobi Garden | Answered on Nov 18, 2019
Without more information, the best guess is that the piston is probably seized in the cylinder, this will not fix itself by adding oil now. It likely needs a new piston and/or rings and/or cylinder or shortblock assembly. You can google your model number for sources of repair parts. Depends what you find when you disassemble it, if you can get the piston out you may be lucky to get by with a new set of rings and honing the cylinder.
But it will be a batch of work for a $200 blower. May be worth it if you can do it yourself and the parts arent too much. Certainly a shop couldn't do it for less than the replacement price of the whole blower.
Ryobi Garden | Answered on Nov 05, 2019
Fix Factor: EasyDuration: 25-30 minutesFrequency: As necessaryTools Required: Receptacle for draining fuel, Phillip's screwdriver, ratchet and socket set, Torx drivers, starter rope (or similar object), spark plug wrench or socket, adjustable pliers, long-nosed pliers, shop rags.
REPLACE STARTER CHORD:
Remove the rear cover.2. Remove the carburetor.3. Disconnect the clutch housing.4. Bind the engine.5. Remove the clutch drum.6. Remove the clutch.7. Remove the starter.8. Remove the starter handle.9. Remove the recoil pulley.10. Remove the starter rope.Installing the New Starter Rope11. Install the starter rope.Reassembling the Unit12. Install the recoil pulley.13. Install the starter handle.14. Reinstall the starter.15. Reinstall the clutch.16. Reinstall the clutch drum.17. Reinstall the spark plug.18. Reinstall the clutch housing.19. Reinstall the carburetor.20. Reinstall the rear cover.
FLYWHEEL REMOVAL:
Use long-nosed pliers to remove the washer from the shaft.
While applying steady upward pressure to the flywheel, firmly strike the end of the shaft with a rubber mallet until the flywheel breaks free. Several blows from the mallet may be necessary to free the flywheel from the engine assembly.
Stating the obvious it is running too lean on the mixture screws, you may well need a special tool to do this, but you need to open ( anti clockwise ) the H screw on the carb about 10 minutes on a clock face, this will richen the mixture and aid acceleration.
Ryobi Garden | Answered on Oct 24, 2019
Sounds like a fuel problem - have you tried using partial choke? At least, this might verify that you just have a fuel problem. The 4-stroke is not as temporemental as the 2-stroke, but worth checking a few simple things : Is there an obstruction in the fuel supply ? Is the fuel tank supposed to be vented - if so, is the vent blocked ? Is there some dirt in the fuel, leading to a blocked jet in the carburetor ? - if so, drain/empty the carburetor, clean sediment & ensure all jets are clear and refill whole system with clean fresh fuel : If the carburetor or any part of it is loose, there might well be an Induction air-leak ( which could impair the engine's intake of fuel ) : And (of course ) - Is the spark-plug badly "gapped" or fouled ? Try to isolate and eradicate in a methodical way, good luck !
Ryobi Garden | Answered on Oct 07, 2019
Check all filters going to and from gas tank.One could be partly plugged.Also Air filter.
Ryobi Garden | Answered on Oct 04, 2019
check the muffler.see if the spark arrester is clogged
Ryobi Garden | Answered on Sep 29, 2019
Ryobi Rht-2660DA Quik Fire Hedge Trimmer 26Cc Logo
Popular Tags
9 questions posted
Top Ryobi Garden Experts
Nick Olsen
Dennis Tokarzewski
Level 1 Expert
Wayne McNeil
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
View Most Popular
Ryobi Garden
  • Ryobi Garden
Most Popular Question
spark arrester rht2660da hedge trimmer
  • Garden
