20 Most Recent HP Compaq Presario 2200 Notebook Questions & Answers
3answers
Unknown device ROOT\NET\0000
goog
12/11/2018 3:04:19 PM • HP Compaq... • Answered on Dec 11, 2018
4answers
Im trying to listen to music at school but
streema.com or streama.com they can stream your local radio stations...but no guarantee, school districts are always finding new sites to block everyday, so it may be blocked in your district by now!!
2/9/2018 6:35:14 PM • HP Compaq... • Answered on Feb 09, 2018
3answers
Webcam driver hp hd-2200
You will probably have to delete the driver from the driver property page. Then reboot the computer. Then make sure there's no driver listed. Then select up the driver. Select that you have the driver. Find a driver. Install.
9/12/2017 8:17:38 AM • HP Compaq... • Answered on Sep 12, 2017
How do you use spell check on wordpad on a HP Compaq computer?
Hello "A" Yes, depending on your configuration PC, or version of windows, or wordpad, using F7, do the trick. good luck Carl
1/26/2017 4:51:27 PM • HP Compaq... • Answered on Jan 26, 2017
0answers
0answers
Wireless connection wont work
To check if the wireless card is bad or OK.
Go to Control Panel - Network Connections - Is the wireless network connection listed and if so is there a red X on this connection?
If so, right click on the wireless and click Repair - this may fix your problem, it forces the wireless router to issue the wireless card with a new IP address.
If it doesn't fix the problem then go to Control Panel - System - Hardware tab - Device Manager - scroll down to Network Adapters and expand and check your wireless card, is it Working and Enabled?
If has a yellow ? against it or not working then reinstall the wireless card driver.
If the wireless card is built-in check the BIOS to see if the wireless card is enabled, if not enable the wireless card and repeat the above steps.
If this doesn't fix your problem then the wireless card is faulty and you need a new wireless card. You can get a PCMCIA wireless card to replace the faulty wireless card. If the wireless card is built-in then disable the faulty wireless card in the BIOS before you install the new wireless card.
10/21/2013 4:13:54 PM • HP Compaq... • Answered on Oct 21, 2013
The touch pad on my Toshiba satellite quit working troubleshoot say missing driver for unknown program the device id is ROOT/NET/000
run a registry cleaner like IOBIT search google its free works great
3/4/2013 9:49:14 PM • HP Compaq... • Answered on Mar 04, 2013
How to completely restore a compaq presario 2200 notebook to factory without disks or the F11 button
Hi,I could get your problem.Actually the primary partition of your pc is messed up. You need to reinstall your OS.To restore deleted partition try this recovery software because this tool is capable of restoring datas and disk volumes easily. You can get the demo version from here .If satisfied purchase the full version as i did..
2/8/2013 10:11:11 PM • HP Compaq... • Answered on Feb 08, 2013
My presario 2200 brightness is not working
The problem is with the LCD PANEL. REPLACE THE INVERTER UNIT IN THE LCD PANEL
1/15/2013 1:54:48 PM • HP Compaq... • Answered on Jan 15, 2013
How can i change the CMOS battery of my Laptop Compaq Presario V2000?
Here is the location of the appropriate Service Manual - you will have to partially disassemble your computer to reach the battery and replace it.http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
9/21/2012 4:40:41 PM • HP Compaq... • Answered on Sep 21, 2012
2answers
CMOS battery on Compaq Presario v2000
Desktop PCs use a battery to keep time when the they are off, much like a watch. Like a watch, the battery needs to be replaced when it runs low on power. Replace the battery using the steps below.
  1. Unplug all cables except for the power. Write down each cable location if you do not already know where it connects.
  2. Unplug the power cable and with the power cable removed press the Power button on the front of the PC.
  3. Remove the screws on the rear of the PC.
  4. Slide the side panel off from the rear of the PC.
  5. Locate the battery. It is a small shiny round metal wafer (like a larger version of a watch battery).
  6. Remember which direction the battery is installed. Usually the engraved side, the positive side, is face up. Remove the battery from the main board.
  7. Acquire the battery and replace it in the same socket it was removed from. Make sure the new battery is installed in exactly the same orientation as the previous battery. (Warning: There is danger of explosion if the battery is not correctly replaced. Replace only the same or equivalent type of battery.
  8. Replace a side panel by matching the side panel tabs with the tab openings in the case.
  9. Connect all cables and turn on the PC to set the time.
  10. Hope this helps. Would appreciate if you rate it. Thanks.2b4f1b5.jpg895f1d9.jpg
8/15/2012 3:35:28 AM • HP Compaq... • Answered on Aug 15, 2012
2answers
I have a old school laptop and it only has one user and wont let me use the administrator what do i do
One User is a Administrator already maybe you need just to unlock some features in your windows
8/14/2012 11:48:22 AM • HP Compaq... • Answered on Aug 14, 2012
Can i turn on my presario 2200 with out the battery
If you are talking about the main battery the answer is yes.
7/20/2012 5:33:51 PM • HP Compaq... • Answered on Jul 20, 2012
My laptop touch pad not working so i want to touch cable\
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Dell Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
5/29/2012 9:51:54 PM • HP Compaq... • Answered on May 29, 2012
Computer will not search
hi,please uninstall and reinstall your internet browser .
5/21/2012 4:55:08 AM • HP Compaq... • Answered on May 21, 2012
HP Compaq Presario 2200 Notebook Logo
219 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
change cmos battery laptop compaq
  • Computers & Internet
