20 Most Recent Craftsman WeedWacker Gas Trimmer 25cc 2-Cycle Curved Shaft Questions & Answers
piston, cylinder and connecting rod. maybe the crankshaft too. engine pretty much.
Craftsman... | Answered on Jun 06, 2018
this is a hard question ,ill start with the text book answer , NO the idle should be low enough to disengage the clutch and remove power from head . but in reality this always is not possible , me I judge a clutch and engine idle % to be working correct if I can put cutting head on ground and not have it take off with throttle closed off
Craftsman... | Answered on Jun 11, 2015
check carb needle valve and diaphrams
Craftsman... | Answered on Mar 08, 2015
-Possible clogged fuel line.
Good luck
Mai
Craftsman... | Answered on May 20, 2014
My suspicion is carburetor (fuel). Possibly water in carb bowl (and tank).
Suggest you drain all fuel. Remove carburetor bowl, drain and clean, reassemble.
Fill with fresh fuel.
If you capture fuel and transfer to a clear glass jar, water is indicated by a discernable line, fuel on top of water.
Comment here with results.
Craftsman Garden | Answered on Dec 22, 2019
Tighten the blade bolt..shaft cud b bent causing vibration. Belts cud b bad
Craftsman Garden | Answered on Dec 09, 2019
the drive wheel is most likely rusted to the hex shaft due to not greasing it often enough
Craftsman Garden | Answered on Dec 02, 2019
Mine was stuck in 3rd gear and all it needs is cleaned get any rust off new grease and oil the shifting gears that's all it needs it's a spicer dana transmission
Craftsman Garden | Answered on Nov 30, 2019
Possibly stuck carburetor float is stuck or debris in inlet needle valve or other.
Craftsman Garden | Answered on Nov 28, 2019
REPLACE THE AIR FILTER, FUEL FILTER AND CHANGE THE OIL AND SPARK PLUG OR PLUGS
Craftsman Garden | Answered on Nov 12, 2019
This eBay seller has parts available for shop equipment and also states he has more unlisted just send him a message.
https://www.ebay.com/itm/Craftsman-Radial-Arm-Saw-Switch-113-29410/264518437848?hash=item3d96870bd8:g:r~MAAOSwd2JdS59h
Craftsman Garden | Answered on Nov 10, 2019
Craftsman WeedWacker Gas Trimmer 25cc 2-Cycle Curved Shaft Logo
18 questions posted
Top Craftsman Garden Experts
john h
Sheldon Dedek
rjivaro
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
View Most Popular
Craftsman Garden
  • Craftsman Garden
Most Popular Question
keeps flooding
  • Garden
