20 Most Recent Husqvarna 128LD 28cc 2-Stroke Gas-Powered Straight-Shaft String Questions & Answers
I replaced the fuel lines on my Husqvarna 128LD and they are now leaking, is there a seal or a grommet of some sort to help seal it at the tank? I don't recall any when I pulled it apart.
Some fuel tanks will have a black rubber grommet that have holes for the fuel lines to go into, if your holes are in the tank itself, then no, there's no grommet. And if that's the case ,your lines are not the correct outer diameter. There are multiple sizes of fuel lines. In my shop I have multiple sizes, if you don't have that kinda stock, you're better off either ordering the ones of a parts drawing of your model or simply take your unit and old lines to the closest small engine shop and have them match em up, u actually can just bring the tank with ya.
10/2/2015 9:54:15 PM • Husqvarna 128LD... • Answered on Oct 02, 2015
0answers
Dethatcher
Be the first to answer 10/2/2015 12:48:46 PM • Husqvarna 128LD... • Posted on Oct 02, 2015Be the first to answer
HOW DO I FIX THE FUEL LINES ON MY husquravana 128ld gas trimmer?
buy new ones and replace one at a time, HUSQVARNA 128LD Fuel Line Fitting PART NUMBER: 530023877 128LD HUSQVARNA TRIMMER Manual
4/27/2015 2:33:05 AM • Husqvarna 128LD... • Answered on Apr 27, 2015
My trimmer runs for a couple of minutes then quits.i have to choke it to restart.any ideas
Most likely a fueling issue. check and clean carb, replace diaphragms if necessary. check fuel lines and fuel filter.
3/15/2015 6:55:16 PM • Husqvarna 128LD... • Answered on Mar 15, 2015
Went to pull cord to crank cord won't budge
May have a ramaged rewind starter, but most likely seized engine
3/15/2015 6:52:43 PM • Husqvarna 128LD... • Answered on Mar 15, 2015
Husqvarna 128Ld wont run after 30 seconds
put the correct spark plug in it and no a CJ8 isnt the right plug !!!
12/28/2013 1:10:58 AM • Husqvarna 128LD... • Answered on Dec 28, 2013
0answers
My husqvarna 128ld won't start
Do you have compression, good spark and is fuel getting into the cylinder.?
8/2/2013 12:40:41 PM • Husqvarna 128LD... • Answered on Aug 02, 2013
Husqvarna Problems
Have you changed the fuel tank vent.? Could possibly be a vaccum being created in the fuel tank, starving the carb of fuel.
8/2/2013 12:39:48 PM • Husqvarna 128LD... • Answered on Aug 02, 2013
I can't get the shaft to click into place. About 1/2 inch of space between the two pieces.
Are they lined up correctly.? There is a video on youtube which shows the full assembly of this machine, that might help you.
7/30/2013 11:39:53 PM • Husqvarna 128LD... • Answered on Jul 30, 2013
Husqvarna 128ld won't start
May have an air leak in the fuel line, primer bubble could be split or the primer bulb base is blocked.
7/30/2013 11:37:00 PM • Husqvarna 128LD... • Answered on Jul 30, 2013
2answers
How do I find out what year my Husqvarna yth18542 42 in riding lawn mower was made in
yth18542 is the model number of the lawn tractor, the identification plate should also show a serial number, which can be used to identify the date of manufacture as well as to differentiate between differences in this model, depending on date of manufacture. https://www.husqvarna.com/us/products/riding-lawn-mowers/yth18542/960430172/
4/16/2024 6:17:40 AM • Husqvarna Garden • Answered 2 days ago
2answers
Governor on briggs 445677
Looks like your governor crank broke. Go to www.parttree.com
4/12/2024 1:16:56 AM • Husqvarna Garden • Answered on Apr 12, 2024
What kind of blade can i put on my Husqvarna 322L weedeater to cut little trees up to size 1/2 to 1?
copy and paste into search engine Husqvarna Blade Conversion 537048502 537 04 85-02 322L 323L 324LX 325LX 326L
3/21/2024 4:41:48 PM • Husqvarna Garden • Answered on Mar 21, 2024
2answers
I have a Husqvarna HU700F. I need a new grass bag. I can only find one for an HU700. Would that fit?
Here is the bag, use your existing frame https://saffordequipment.com/product/husqvarna-black-grass-bag-oem-580947302/ Husqvarna Black Grass Bag OEM #580947302 **Bag Only, Does not come with Frame** Compatibility This part is compatible with the following machines: Husqvarna HU700F (2012-11)(96145000900) Walk Behind Mower Also available at Walmart and Sears https://www.google.com/search?q=husqvarna+hu700f+grass+bag
OEM Husqvarna 580947307 Fabric Grass Bag ONLY For ...
Walmart https://www.walmart.com > OEM-Husqvarna-580947... Husqvarna. OEM Husqvarna 580947307 Fabric Grass Bag ONLY For HU550F HU550FH HU700F HU800H. USD Now $55.00. You save $14.58. You save$14.58. was $69.58$69.58. US$55.00 ..
1/28/2024 8:02:53 PM • Husqvarna Garden • Answered on Jan 28, 2024
Husqvarna YTA24V48 Lawn Tractor. Need drive belt diagram for it please?
Question edited for clarity. Shown on Page 20 of the manual. https://www.manualowl.com/m/Husqvarna/YTA24V48/Manual/493664?page=20 ..
11/29/2023 9:34:18 PM • Husqvarna Garden • Answered on Nov 29, 2023
Husqvarna zero turn 560 lawn mower how do I raise the seat
See attached. .. manual available at
https://www.husqvarna.com/us/support/z560x/
11/25/2023 1:15:01 PM • Husqvarna Garden • Answered on Nov 25, 2023
How do I pour gas into my carborator when I run out of gas
why, just fill tank
10/28/2023 8:18:43 PM • Husqvarna Garden • Answered on Oct 28, 2023
3answers
Husqvarna zero turn mower. Starts ok, but when I bring in the right handle the engine dies. The left is ok, I can move it in and go forward slightly with it, but when I engage the right handle the engine shuts off.
Your seat safety switch is not working. If the seat switch isn't activated, ie. a person sitting on the seat, the safety system will stop the engine when the levers are engaged. There is probably only one lever safety switch, on the right lever, which is why the left one doesn't kill the engine. Check the seat switch continuity and the wiring for loose connections.
10/7/2023 2:37:40 AM • Husqvarna Garden • Answered on Oct 07, 2023
Husqvarna 128LD 28cc 2-Stroke Gas-Powered Straight-Shaft String Logo
13 questions posted
Top Husqvarna Garden Experts
Jay Finke
Jay Finke
Sean Wright
Sean Wright
Thomas Perkins
Thomas Perkins
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
View Most Popular
Husqvarna Garden
  • Husqvarna Garden
Most Popular Question
fix fuel lines husquravana 128ld gas
  • Garden
