20 Most Recent
Echo 21.2 cc Gas PAS Power Source PAS-225AAC Questions & Answers
Fuel and prime lines
there are three lines for fuel. 1 is from carb to tank with filter. 2 is from carb to tank just below gas cap on tank as a return line 3 is from tank to anywhere outside the tank for venting.
Weedeater want reb up put new carburator 230 echo weedeater
I know this is a very old post, but figured I'd answer it so any others with this issue can have the fix.
With Echo trimmers not revving to speed although they start with no problem, the issue is usually the muffler screen. It becomes plugged with carbon because of improperly mixed 2 stroke fuel.
Remove the screen from the muffler and burn off the carbon with a propane torch, or wire brush it off. Once cleaned engine should rev to speed.
6/25/2022 4:53:50 PM •
Echo Garden
Answered
on Jun 25, 2022
I don't know what fuel my leaf blower needs.
Almost every leaf blower uses gasoline mixed with 2-cycle mixing oil. Unless you have a larger, commercial model with a separate oil tank, you'll need to purchase mixing oil and mix it with your fuel. You can find mixing oil at
PartsBuggy.com.
5/6/2021 5:12:27 AM •
Echo Garden
Answered
on May 06, 2021
