20 Most Recent
HP LaserJet 4100n Printer Questions & Answers
How do I fix a 49.FF04 Service Error on an HP Laserjet 4100n
This could be several things. But most are firmware related
Unplug it from the network and power it off, then on. Does it come to ready? If it does there's a bad print job on someone's computer. Or less likely the network port is bad. Clear out all print jobs on the network then submit a new print job. If it prints, great, if it codes again, clear it and try from a different computer.
if you're printing from a Mac can probably get away with updating firmware or changing the PPD for the printer.
if its windows printing I would replace the formatter board. If you have one lying around you could try plugging in a jet direct card and seeing what it does, but I wouldn't order a jetdirect card, I'd replace the formatter.
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
I have an HP Laserjet
try when you get to print , you go to properties or printer settings and click on the draw number yo want the paper to feed from apply and then make it your default drawer
Laserjet 4100 taking in extra paper
Hello,Picking up more than one sheet of paper indicates the pickup rollers and separation pad is worn and they will need to be replaced. These parts work together to pickup and separate the paper from the paper tray and when they get slick the rollers allow more than one sheet to enter the printer which causes a paper jam and misfeed errors. The rollers and separation pad come in a kit and is user installable, no need to pay big money for a repair shop to do it for you. The kit RK-4100 is available here:
http://www.ccl-la.com/catalog/product_info.php?products_id=259
