20 Most Recent HP OfficeJet 7110 All-In-One Thermal Printer Questions & Answers
4answers
Hp officejet 7110 battery and cmos location
The battery is located behind the left front cover. Open the printer, grasp the left front cover from inside the printer and pull to open. Look inside the printer to left and you will see it.
It is enough to remove for a minute to reset the expiration.
But I'm afraid after that the printer may not keep the date and time when turn off.
1/11/2023 12:13:12 AM • HP OfficeJet... • Answered on Jan 11, 2023
Reset HP 7110 to factory settings
usually setting your computer to a date before the expiration date of the cartridge. If your printer has a date function try this first on your printer.
5/15/2019 3:20:26 PM • HP OfficeJet... • Answered on May 15, 2019
HP Officejet 7110 won't print black and white w/o color cartridge
I've used HP Inkjet/Officejet printers for years. Many HP inkjet printers also use the color cartridges to some extent to create 'black' in slightly different shades, that can be un-noticeable to the eye. To print using only black ink, try doing as follows: When you click on 'Print' from your browser, the printer properties (or preferences) page opens. You must first set the printer to not print in color (color is the default setting). Then you must set the printer to use 'black ink only' by using the 'advanced settings' as follows: 1. In most browsers there will be a box on the lower right of the printer properties page that says 'advanced'. 2. Click on that box to get the advanced settings page to open. 3. Once open, the feature you need to check is called 'print in grayscale'. (It is usually at the top of the list) It is set to 'off' by default. Just click on it and a menu box drops down and one of the choices is 'Black Ink Only'. 4. Click on that and then 'save' or 'apply' those settings. Then your printer should be using black ink only. You will probably have to set that each time you want to start a new printing job, as the default settings on these printers are tilted toward using the color cartridges in order to sell you more colored ink. Also, if you are using Windows 10 and the 'Edge Browser' that comes with it, you cannot get to the 'grayscale' option. So either use a 3rd party browser, or use good old Internet Explorer, (which is still included in Windows 10) to open and get to the page you are trying to print. I hope this helps. If not, go to HP.com and type in the model number of your printer and then do a search from there for detailed instructions for your printer model (which might be slightly different than what I have shared here.
4/28/2017 5:29:23 AM • HP OfficeJet... • Answered on Apr 28, 2017
Prints extra blank page for every one page of printed material
Reduce the amount of paper in the print try.
4/7/2016 6:42:42 AM • HP OfficeJet... • Answered on Apr 07, 2016
Hp printer 7110
Check your user manual.
9/4/2015 10:15:45 PM • HP OfficeJet... • Answered on Sep 04, 2015
0answers
Reset HP 7110
Be the first to answer 5/13/2014 3:48:44 AM • HP OfficeJet... • Posted on May 13, 2014Be the first to answer
2answers
Scanner Error Turn printer off & back on
i m italian my inglish is not good... i solve the problem clean the guide of the carrel of the light... so i can run more easy...
3/23/2014 1:05:24 PM • HP OfficeJet... • Answered on Mar 23, 2014
0answers
0answers
2answers
Scanner Failure, 'Power off and on' message - therefore, fax will not work
Scanner failure will not let you to make copies nad scan but you will be able to print from computer and receive fax.
Even then try the steps mentioned bellow:
Remove both the ink cartridges from the All-In-One.
Unplug the power cord from the All-In-One as well as the power outlet.
Now move the carriage (carriage is the one which holds the cartridge) Too and Fro till you feel the carriage is moving smoothly.
Then insert the cartridges close the access door.
Plug the power cord directly to a wall outlet without surg protector (If possible connect it to a different power outlet)
Before connecting the power cord to the All-In-One press and hold the # and no 6 button and then insert the power cord, do not release the keys
until you see a message a reset (if the screen goes blank then release the keys and turn the power on)
Now try printing Printing from computer,
If you are able to print from computer you should be able to receive faxes.
Try printing a test fax.
Press Menu/Setup> Then press the right arrow key to locate Tools> Then Press Ok> Again press the right arrow key to locate Run Fax Test> And press OK
Check to see if it prints a Fax test
Good Luck
11/6/2013 8:41:16 AM • HP OfficeJet... • Answered on Nov 06, 2013
0answers
2answers
I am looking for HP Officejet 7110 Service Manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
http://h10032.www1.hp.com/ctg/Manual/c00043301.pdf
try downloading from any one of these links
9/23/2013 12:16:00 PM • HP OfficeJet... • Answered on Sep 23, 2013
When trying to send a
Try adjusting the paper size that the printer thinks you are using
7/1/2011 2:03:49 PM • HP OfficeJet... • Answered on Jul 01, 2011
Please,I have lost my drivers
Please go to the link below; select operating system and the drivers will appear and you can download them.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=91472&
If link does not work copy and past in to browser.
Hope this helps!
Regards,
4/14/2011 7:27:37 PM • HP OfficeJet... • Answered on Apr 14, 2011
I just replaced the printer cartridges and ran a
Maybe the print quality if set to text print quality, change it to photo print quality to get print quality.
1/2/2011 8:36:29 PM • HP OfficeJet... • Answered on Jan 02, 2011
All the lights on the printer are flashing off and
Re-initialize the HP all-in-one
Force the HP all-in-one to reinitialize by following the steps below:
1. Turn the unit off by pressing the ON button.
2. Disconnect the power cord.
3. Wait five seconds, then reconnect the power cord.
4. but before plugging the unit back in, press and hold the # and 6 keys on the HP all-in-one numeric keypad. Continue to hold these keys down for a few seconds after plugging the unit back in to reset it. Once the all-in-one re-establishes communication with the computer, reset the language and country.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
12/29/2010 1:28:44 AM • HP OfficeJet... • Answered on Dec 29, 2010
HP OfficeJet 7110 All-In-One Thermal Printer Logo
163 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
replaced both print cartridges but print
  • Office Equipment & Supplies
