20 Most Recent
HP LaserJet 1320 Printer Questions & Answers
Hp LaserJet 1320 will not print multiple copies
This problem is caused by Mopier Mode being enabled by default. The idea of Mopier Mode is to minimise computer and network traffic by sending only 1 copy to a printer equiped with suitable internal memory. That stored copy is then used to produce the multiple copies. Most HP Laserjets do not have suitable internal memory and so only the one copy sent by the computer gets printed. To disable Mopier Mode:
Click Start
Click Devices and Printers
Right click your Laserjet Printer
Select Printer Properties
Click the Device Settings Tab
Scroll down to the bottom
If necessary, expand Installable Options
Click on Mopier Mode
Select Disable in the selection box that appears
Click Apply
You will now get multiple copies.
How to reset HP 1320N to factory default
For me worked this:
- Turn off the printer
- Turn on the printer
- Push and mantain pushed the button on the back of the printer (near to USB connector) for 30 seconds.
- Release the button
- With 1 to 3 minutes for DHCP Server (if you have one)
The
printer now have a default configuration, if you have a DHCP server
your printer now have a IP Address of your DHCP Server's IP pool.
- Print a coniguration page holding down the green button until the attention LED is blinking
- Release it, 3 pages will be printed.
It is done
HP Laser Jet 1320 Printer installation SPAM BELOW AT 1*800*532*4187
Just downloading the PCL5 driver was not enough for my computer. Maybe it is enough for other users' computers. But in addition to downloading the drivers, i had to also download and install the "HP Laserjet 1320 plug and play print driver solution" at the bottom of the driver list. Save the file to your desktop, double-click it and follow instructions to install, then reboot. Then when I checked my printer list, the HP Laserjet 1320 was there. I printed a test page, and now i am good to go. Hope this helps.
My hp 1320 prints only one copy SPAM I AM AT 1*800*532*4187
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system.
This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Hp Laserjet 1320 orange light is blinking and printer is not printing the document
Attention light is blinking
This state can be reached in
the following circumstances:
?Paper tray is empty
?Door open
?Paper jam
?Misfeed from tray
1.Verify that the print cartridge is present and that the print-cartridge door is closed correctly.
2.Verify that media is present in the input tray.
3.Clear any jams and perform paper-path functional checks.
4.Make sure that the interlocks are operating correctly.
To reset the printer after a jam, press the GO button
Hp laserjet 1320 has no power at all.
Try connecting the printer to a circuit board (one with a circuit breaker) to ensure overvoltage is minimised. Next check that the printer has the appropriate power setting (220v/110v Depending on your area.) Ps- not all fuses are the same , if you have the original 1 look on the adaptor and it will say 220/110V at ?A thats the proper fuse to get ,if you replaced a different fuse (lower rating) it will go out instantly.if the fuse still goes out you will need to ask Hp for a replacement adaptor for your printer.(if none is available you need to either take it to hp (costly) or buy another printer .
Hope it helps
Problem:
Not able to print mirror
To reverse an image for iron-on transfers
1. On the File menu in your software application, click Print.
2. Make sure the product is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Click the Features tab.
5. In the Paper Type drop-down list, click More, and then select HP Iron-on Transfer
from the list.
6. If the selected size is not what you want, click an appropriate size in the Size list.
7. Click the Advanced tab.
8. In the Features area, select the Mirror Image checkbox.
9. Click OK, and then click Print or OK in the Print dialog box.
For support call Our Toll-Free 1 888 224 4280
I have a HP LaserJet 1320tn, after I changed the
Hi if you says that the paper gets jam at the fuser meeting point than i m sure that registration assembly which register the paper with toner cartridge is not working properly this is internal hardware fault.
It may caused due to faulty pickup assembly too.
There is a small **** manual feed tray try to print using manual feed and check if the problem persists then registration assembly is faulty if the it print fine from manual feed than Tray 2 pickup assembly or pickup roller is faulty.
