20 Most Recent KitchenAid Kitchen Aid KSM150 Artisan 5 Quart Stand Mixer Questions & Answers
KitchenAid stand mixer KSM150 was run without locking down the motor housing. Now the motor head "wobbles" when the mixer is operating. I've tried adjusting the screw located under the head but it c
The screw under the head is for adjusting the head height for when the standard paddle and bowl are being used. First tip the whole machine upside down and tighten the hinge pin screw right up inside the pedestal post. Next reset the head height with flat paddle. Screw in is head down, screw out is head up. You want the paddle to just stop tinging the bowl on high speed.
10/5/2019 8:23:51 AM • KitchenAid... • Answered on Oct 05, 2019
KitchenAid KSM150 bowl won't stay put
If the base is not holding the bowl properly then only a replacement base plate or another bowl is going to fix it. The base plate is held onto the pedestal with 3 Philips head screws.
10/5/2019 8:19:52 AM • KitchenAid... • Answered on Oct 05, 2019
Kitchenaid KSM150 Mixer's speed Off has become High and speeds 1-10 have become Off
The starting position for those top speed control plate screws with the lock nuts it 8 full turns in when you fit the plate. Correct adjustment begins in or out from that point. The bottom screw should have been left where it was to start with as that is for adjusting the start position so that when the lever closes the switch contacts to start the mixer the plate only starts moving when the lever moves to the second click. Try and get the bottom one roughly right and then work on the top ones. Turn it to the first click on the speed lever and then EVENLY adjust the 2 top screws to have the planetary turn 13 to 15 times per 15 seconds. Lock up the lock nuts and then check that the bottom screw is in the correct position with speed increasing a small amount as the lever slips into the second click.
9/19/2017 8:26:44 AM • KitchenAid... • Answered on Sep 19, 2017
I'd be looking at making sure the beater is not banging on the bowl and that the head hinge isn't loose. The bowl is secure on the base with this system that has been in use for decades so you are looking for a fault not a re-design of the system. The friction of the mix in the bowl should logically tend to tighten the bowl, not undo it. I have seen a malformed bowl once where the lugs weren't big enough and I suspect that it's possible for there to have been the odd malformed bottom plate with not big enough lugs.
7/11/2017 5:01:23 AM • KitchenAid... • Answered on Jul 11, 2017
Makes a grinding noise at higher speeds
If it is leaking you are going to have to go inside the gearbox to change the grease so whatever is wrong inside may become obvious when you take it apart. Remove accessory cap from the front and look for any dryish grindings inside there.
10/19/2014 12:03:02 AM • KitchenAid... • Answered on Oct 19, 2014
The screw underneath the head of my kitchen aid mixer is tight, but the head is still wobbling. It isn't a beater adjustment--I already tried that. The head of the mixer is tilted forward a bit--in
When you have the head lifted up the screw you can see in there from the front in the middle by the hinge is the head height adjuster. You need to set the height correctly now so that FLAT PADDLE just clears the bowl. Unscrew it anti clockwise to raise the head. Once that is done turn the machine upside down on a towel and check that the locking screw on the hinge pin is tight, it\'s right up inside the pedestal.
8/12/2014 6:36:33 AM • KitchenAid... • Answered on Aug 12, 2014
KitchenAid Professional 5 Quart stand mixer grain mill won't grind?
From what I know about these and industrial Hobart mixers is that where drive gears are on a shaft they are held by a shear pin that goes right through the gear and the shaft. They are made to shear if the grinder or planetary head is strained. It shears the pin instead of damaging the motor or shredding gears. When they do shear, there is often enough friction to turn the attachment, but not enough force under load. I see two shear pins in this diagram 19/8 and part 14/8. The diagram also show the orientation of bevel gears. https://www.google.com/search?q=olympus+s924+manual A Moulinex Coffee Mill might be a better solution for grinding wheat. ..
4/16/2023 11:16:47 PM • KitchenAid Food... • Answered on Apr 16, 2023
New Artisan Kitchenaid mixer KSM150 out of the box, head won't lock.
Don't forget if it is new it is under manufacturer warranty. Make the beater isn't too low and fouling, because the bowl is set too high? Try to lock with no beater.
3/25/2023 5:11:48 AM • KitchenAid Food... • Answered on Mar 25, 2023
3answers
Trying to adjust the beater to bowl clearance on my bowl lift KitchenAid K5SS. Mine has only pairs of screws, unlike manual diagram
Possibly one screw for up and one for down, working on a see-saw mechanism.
2/6/2023 9:52:44 PM • KitchenAid Food... • Answered on Feb 06, 2023
How to convert kitchenaid mixer from 220v to 110v
It's perfectly save to use a power converter from 220v to 110V. The 50Hz Frequenz will let the Motor spin 20% slower. So it'll last forever. I use a KSM90 from the US in Germany for more than 25 years. It runs great and the gears inside it look like new.
2/5/2023 12:30:16 PM • KitchenAid Food... • Answered on Feb 05, 2023
Kitchenaid Professional 6 Quart Mixer. The speed lever is stuck.
Question edited for clarity. Question moved to category. The speed lever is electronic. Videos and the part in the link. https://www.google.com/search?q=Kitchenaid+Professional+6+mixer+speed+lever+stuck ..
12/19/2022 12:42:07 AM • KitchenAid Food... • Answered on Dec 19, 2022
3answers
Kitchenaid mixer repair manual
google kv25g0xwh manual
7/30/2022 5:31:02 AM • KitchenAid Food... • Answered on Jul 30, 2022
2answers
How am I to disassemble my KitchenAid 7 speed hand mixer?
Try this video although '7 Speed' isn't an Alpha Numeric model number :>) https://www.google.com/search?q=disassemble+my+KitchenAid+7+speed+hand+mixer ..
7/30/2022 5:20:45 AM • KitchenAid Food... • Answered on Jul 30, 2022
Can i use it to make panko?
Panko are made with a special non-fermented bread that has no crust. You can however make good breadcrumbs with old hard bread and if you want it to be like Panko, pulse it and leave the crumbs coarse. I am a trade chef and use Panko a lot. Panko (???) is a type of flaky bread crumbs used in Japanese cuisine as a crunchy coating for fried foods, such as tonkatsu. Panko is made from bread baked by electrical current, which yields a bread without a crust, and then grinding the bread to create fine slivers of crumb.[1] It has a crisper, airier texture than most types of breading found in Western cuisine and maintains its texture baked or deep fried, resulting in a lighter coating.[2] Outside Japan, its use is becoming more popular in both Asian and non-Asian dishes. It is often used on seafood and is often available in Asian markets, speciality stores, and, increasingly, in many large supermarkets. Panko is produced worldwide, particularly in Asian countries, including Japan, Korea, Malaysia, Thailand, China, and Vietnam.
2/26/2022 5:54:01 PM • KitchenAid Food... • Answered on Feb 26, 2022
How do the governor and speed control plate work in a Hobart Kitchenaid K5-A stand mixer?
Before you swap it out, get a can of electrical contact cleaner and spray the track and contacts.
2/22/2022 3:20:17 PM • KitchenAid Food... • Answered on Feb 22, 2022
2answers
Kitchenaid KSM5 mixer - the power lever is hitting/missing to turn it on.
Sounds like your switch is going bad if it's an older machine that would be my guess and I usually guess right
11/26/2021 8:32:49 PM • KitchenAid Food... • Answered on Nov 26, 2021
KitchenAid Kitchen Aid KSM150 Artisan 5 Quart Stand Mixer Logo
7 questions posted
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Food Mixers
Most Popular Question
kitchenaid stand mixer ksm150 run
  • Food Mixers
