20 Most Recent Blomberg WM87120 24" Front-Load Washer with 2.15 cu. ft. Capacity, 16 Programs, 1,200 RPM Spin Speed, Automatic Wash, Internal Heater, LCD Display and Child Lock Questions & Answers
3answers
Error code 1000 on blomberg washer
We found a way to reset the computer and solved the problem. 1. Press and hold pause turn off machine and turn back on holding pause all the while. 2. This should reset the computer. All lights will light up on LCD display. 3. Release pause button. Turn off machine, turn back on and begin a new wash cycle. woo hoo!
5/27/2017 3:47:01 PM • Blomberg WM87120... • Answered on May 27, 2017
The machine shows E07 error upon entering the service menu.
Door latching or lock error ·Door not detected closed ·Check door is closed ·Check door catch and latch ·Check door lock wiring Check door lock
3/16/2024 8:44:03 PM • Blomberg Washing... • Answered on Mar 16, 2024
I can't reboot my Blomberg compact washer after changing the main control board.
you're facing with your Blomberg compact washer. Here are some steps you can try to reboot your washer after changing the main control board:
  1. Unplug the washer from the power outlet and wait for at least 5 minutes. This will allow the internal capacitors to discharge and reset the control board.
  2. After 5 minutes, plug the washer back into the power outlet and ensure it is properly connected to a reliable power source.
  3. Press and hold the "Start/Pause" button for at least 5 seconds to reset the washer. This may trigger a reboot of the control board and allow the washer to reset to its default settings.
  4. If the washer still does not reboot, you can try performing a factory reset. To do this, unplug the washer from the power outlet, and while holding the "Start/Pause" button, plug it back in. Continue to hold the button for another 5 seconds until the display shows "rES" or "rCL." Release the button and wait for the washer to complete the reset process.
  5. If none of the above steps work, you may need to refer to the user manual or contact Blomberg customer support for further assistance. It's possible that there could be other underlying issues that require professional diagnosis and repair.
Remember to always exercise caution when working with electrical appliances and consider seeking professional help if you're not familiar with the troubleshooting steps. slide_washers-undefined-undefined-0.jpg
4/10/2023 8:18:15 PM • Blomberg Washing... • Answered on Apr 10, 2023
2answers
My Blomberg washer attempts to agitate, but suddenly shudders and stops. Even when virtually empty. I assume it's the motor. I changed the brushes, but no change. Is there a way test it to be sure?
check under agitator see if cogs are bad if ok then bad transmission if motor hot could be turning off bad motor
3/25/2023 6:11:17 AM • Blomberg Washing... • Answered on Mar 25, 2023
My Blomberg washing machine keeps on blinking on the screen "Door".
Try disconnecting the mains power to reset the Control Board.
12/17/2022 5:27:52 AM • Blomberg Washing... • Answered on Dec 17, 2022
Solved: Issue with starting Blomberg GreenPlus washing machine after pausing a program
Hi, please check the troubleshooting section of your manual for any procedure related to the flashing-start sign. If this is not the in the manual, then you might need to schedule servicing/repair on the machine from the manufacturer by calling 1(800) 459-9848. Thank you.
10/5/2022 8:24:11 PM • Blomberg Washing... • Answered on Oct 05, 2022
Blomberg Washer WM87120 NBL00 My Start Button is stuck in and I can't start the washer or even try to reset the washer with the On/Off. Do I need to replace the control panel ?
This machine is by far the worst I have encountered for finding parts. I just went through 18 pages and there was nothing that looked like a control panel. Most sites has a Parts Schematic by the area of the machine the parts are in. https://www.google.com/search?q=blomberg+washer+wm87120+nbl00+control+board Manual https://www.manualslib.com/manual/622179/Blomberg-Wm-87120-Nbl00.html?page=19#manual ..
4/22/2022 1:31:39 AM • Blomberg Washing... • Answered on Apr 22, 2022
Blomberg LW128441 is not working on wash programes why?
No agitation? first use a multi meter and check ur water pressure switch? that is what sends the machine the message to start wash cycle? You can test it with a meter and with a manual test? ( first locate it in the panel, it has a plastic clear tube hose going into it, remove that tube from its connection, now put another small tube or hose into the slot where it was and have the machine set to wash cycle with water in it. Blow into the other end of the tube. If the machine starts to wash. the pressure switch is more than likely good ( If No wash- then THE DIAPHRAGM IS BAD AND SWITCH HAS TO BE REPLACED) another test u can do is Remove the hose and submerge in water. Seal one end and blow air into the other end and look for bubbles. Check for an obstruction in the hose as well. Or take the original hose tube and plug one end and blow into it AT the other end, it should be hard and have pressure, if it is easy to blow and u dont feel any pressure and it feels like the air is going out ? Sometimes they get busted open or a pin hole and release air causing the water switch diaphragm to not open. Another test u can make with a multi meter is by testing the prongs individually. # 15,16,17 (don't worry to much bout the numbers IF U GET THEM WRONG) place ur meter prongs on both out side prongs or connectors of the switch. (where the wire plugs into) take note of weather it shows OHMS or infinity ( open or close circuit) ? Now place the meter on the left outside and the middle prong, take note agin what it shows. Now place meter prong on the right outside and the middle prong. Agin take note what reading u get. ( you should actually get a reading of infinity in 1 and a reading of continuity or ohms in the other 2? Now the tricky part. Agin place a small tube or hose into the switch and blow into it, using the meter do the same test agin on all prongs. But now keep the pressure on the switch when u blow into it, in other words use ur tongue on one end of tube to not allow air to escape. When u test it agin now one of the prongs that once read infinity should now show continuity or ohms, and 1 of the other prongs that read ohms should now read infinity or open. . If both check ok then next CHECK the motor coupler (a bad coupler can be checked by looking under the machine and taking note if there is a black residue on floor, look at coupler located between the motor and tranny, and see if it is broken up or missing any parts? Try to turn shaft by hand and notice if it does not engage tub? ) or belt if belt driven. Check for loose, broken or worn belt . Then check the door switch with a multi meter for continuity OHMS when door closed and infinity when door is opened , and if there is a little movement on wash cycle in 1 direction only then check the cam dogs in agitator. Also check THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS. However in G.E models the cam dogs are replaced with what is called an agitator coupler. (located at bottom of tub) Remember to check the agitator spline as well. for worn broken teeth By the way my advice is free cuz God is good! No spin, or lite spin try these: bare in mind that many times there is no spin it can be due to a clogged water pump so check it for debris and or broken propeller. Other items to check Using a multi meter check for continuity the door switch, which when bad may not allow agitation or spin. Bare in mind the lid switch assembly can fail either mechanically or electrically. Check the clutch, motor coupler, brake assembly, transmission, and mode shifter or actuator. one way to check for slipping is to get under the machine after a spin cycle ( this is if u get a lil spin but not much leaving clothes still wet) mix in a spray bottle a lil water and some dish detergent, then spray it on the clutch assembly ( the metal round pc. Connected to the tranny) if it sizzles and steams up then u know its bad and slipping. Another way to check clutch if u get no spin at all? Is to take it out and use ur hand to try and turn the inner spring assembly pushing it around the inside? If its very easy, it BAD should be hard to push by hand. Or try the hand test: If no hammering sound has ever been heard out of this machine, one of the unofficial tests we professional appliantologists will do in the field is called the Hand Test. WARNING: This test is not sanctioned by Whirlpool Corporation; it involves bypassing safety equipment and then putting your hand on and near rotating machinery which could result in injury, dismemberment, disfigurement, disembowelment, mangling, hideous screaming, and a ****** *****. Proceed at your own risk! Have a nice day. - put the timer on a spin cycle and open the lid - grab the inner basket with maybe 30% to 40% of your hand strength with your left hand - turn on the machine and bypass the lid switch by depressing the lid switch with a key until the machine begins to spin - if the clutch is engaging properly, the basket should immediately begin to spin and slip through your hand - if it takes very little force to stop the tub from spinning, the clutch needs to be replaced. Next check the motor coupler which engages the tub and tranny to the motor. ( if its bad u usually get no wash or spin or very little of either) Next if belt driven check for a loose, worn or broken belt. And on some models there is no clutch but rather what is called a splutch. And a MODE shifter. These can go bad and effect the spin cycle. On some front load models u may need to check the STATOR assembly. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed. Sometimes a no spin machine can be due to a plugged waterpump hose or obstructed water pump propeller. Check these by eye and hand. And in some models check with a meter for continuity and voltage. LID SWITCH TEST- next step is to  HYPERLINK "http://fixitnow.com/wp/2003/08/31/mailbag-opening-a-whirlpool-or-kenmore-direct-drive-washer/" remove the cabinet and jumper the lid switch harness (tan to gray). Put the unit in spin and watch the shiny metal clutch disc that is on top of the transmission where the shaft comes out. If the machine starts and runs in spin, check to see if the disc is spinning. If it is, then the problem is not in the gearcase- look for trouble in the  HYPERLINK "http://www.repairclinic.com/SSPartDetail.aspx?s=t-whirlpool+clutch-%3d%3di2670&PartID=2670" o "Clutch for a Whirlpool direct drive washer" "_blank" clutch,  HYPERLINK "http://www.repairclinic.com/referral.asp?R=154&N=1254" o "Basket Drive for a Whirlpool direct drive washer" "_blank" basket drive or the  HYPERLINK "http://www.repairclinic.com/referral.asp?R=154&N=2858" o "Drive Block for a Whirlpool direct drive washer" "_blank" tub drive block If, on the other hand, the disc is NOT spinning, check for a problem with  HYPERLINK "http://www.repairclinic.com/referral.asp?R=154&N=2855" o "Motor Coupling for a Whirlpool direct drive washer" "_blank" the motor drive coupler or one of its retainers. This washer doesn't have a belt. Instead, the motor is directly coupled to the gearcase by a drive coupler; that's why it's called a direct drive washer. Read more:  HYPERLINK "http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/" l "ixzz3XW7eZwiN" Diagnosing and Repairing Spin and Agitate Problems in a Whirlpool / Kenmore Direct Drive Washer  HYPERLINK "http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/" l "ixzz3XW7eZwiN" http://fixitnow.com/wp/2010/07/07/diagnosing-and-repairing-spin-and-agitate-problems-in-a-whirlpool-kenmore-direct-drive-washer/#ixzz3XW7eZwiN By the way my advice is free cuz God is good! water pressure-switch-location-undefined-undefined-0_1.jpg water pressure switch how2removswitch-undefined-undefined-2.jpg water press switch-undefined-undefined-4_1.jpg
8/15/2021 10:10:46 AM • Blomberg Washing... • Answered on Aug 15, 2021
New Blomberg, forgot about the bolts on the back of machine
All the transit bolts do is fix the drum in place. If you ran the machine, all that would happen is that it would try to jump around during spin. The groan, sounds like a bearing is seized or the motor is defective. https://www.google.com/search?q=Blomberg+washer+repair+near+me ..
6/22/2021 4:05:26 PM • Blomberg Washing... • Answered on Jun 22, 2021
Blomberg washer door lock symbol constantly on how can I get it off so I can open door normal way
There are two locks on them. Child Lock, C-On, and C-OFF. and Door Lock due to water level. The latter one should unlock a few minutes after the wash ends. If it doesn't, you need a service call. Cutting the power should reset it. https://www.google.com/search?q=Blomberg+washer+door+lock+symbol ..
5/25/2021 7:21:31 PM • Blomberg Washing... • Answered on May 25, 2021
Blomberg LWF28442B Water fills then it has about 2 minute delay then water drains out. It doesn't go in to the spin then switches off
Could be a defective cycle timer or failure of one of the elements controlled by the timer.
1/10/2021 3:37:39 PM • Blomberg Washing... • Answered on Jan 10, 2021
Blomberg and e1 and code
Defrost sensor needs to be changed in freezer
6/12/2020 9:13:21 PM • Blomberg Washing... • Answered on Jun 12, 2020
I have a wash machine blomberg when turn it on the drainer pump on an not atart the program please help
Open drain hose and clean it from coins and other things in the hose
4/10/2020 8:26:19 AM • Blomberg Washing... • Answered on Apr 10, 2020
3answers
How to reset my washing machine blomberg
you cannot reset it anyway its NOT that, you have a door sensor fault most likely or a MCU problem look get a service manual and follow that.
2/13/2020 10:41:52 AM • Blomberg Washing... • Answered on Feb 13, 2020
Blomberg washer does not start
If the machine is dead and there are no error codes,
check the circuit fuse or circuit breaker to ensure the circuit is hot.
If your getting an error code post it here.
If the door doesn't shut properly, it will keep the machine from operating thinking the door is still open. Check the door carefully to make certain the door switch is operating
If the program can’t be selected then this is probably an issue with the water pressure or line voltage. And the appliance will have switched to self-protection mode to prevent any potential damage.
7/13/2019 5:37:42 PM • Blomberg Washing... • Answered on Jul 13, 2019
Blomberg WM87120 24" Front-Load Washer with 2.15 cu. ft. Capacity, 16 Programs, 1,200 RPM Spin Speed, Automatic Wash, Internal Heater, LCD Display and Child Lock Logo
1 questions posted
Top Blomberg Washing Machines Experts
vince
ADMIN Andrew
ADMIN Andrew
Stan Ford
Are you a Blomberg Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Blomberg Washing Machines
Most Popular Question
error code 1000 blomberg washer
  • Washing Machines
