20 Most Recent
Panasonic Toughbook CF-51 Notebook Questions & Answers
How do I reset the bios Password on a Panasonic Cf-51
If you have forgotten your bios password on your Panasonic Cf-51, there is no need to worry. There are a few simple steps that you can follow in order to reset the password and regain access to your computer.
First, locate the RTCRST jumper on the motherboard. This is usually located near the CMOS battery. Once you have located the jumper, remove it and then replace it in the opposite position. This will reset the bios password.
Next, locate the power button on the front of the computer. Once you have located the power button, press and hold it for a few seconds. This will reset the power to the computer and will also clear the bios password.
I hope this helps!
11/22/2022 4:46:24 PM •
Panasonic...
Answered
on Nov 22, 2022
Keyboard is stuck in numeric mode. Can't type
On the Panasonic Toughbook CF-51 there is a key located on the top right next to the F12 function key called "NumLk" or Num Lock.
Press this key once and the embedded numeric keypad is enabled.
Press it a second time and it is disabled.
How do you know if it is enabled or disabled?
Simple: Observe the LED above the keyboard. If the second light with the square symbol and the number "1" is lit up, then the NumLock is enabled. If that LED is not lit up it is disabled.
Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
10/2/2017 8:38:52 PM •
Panasonic...
Answered
on Oct 02, 2017
Turn wireless lan
On page 75 and page 76 of the Reference Manual
for the Panasonic Toughbook CF51 is described
the procedure to turn "on" the wireless lan:
1 Double-click on the taskbar.
2 Select your wireless LAN adapter and select [General].
3 Select [On] for [Switch radio].
4 Select [Networks] and select [Add].
5 Enter the profile name and network name (SSID), and then make
other necessary changes, then select [Next].
6 Make necessary changes and select [Finish].
Please note that there is no Physical Wireless Switch
on the Panasonic Toughbook CF51.
You can find the manual here and double-check yourself:
https://panasonic.ca/PCS/OperatingInstructions/CF51MK1_X_E_Reference_Manual_A.pdf
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
2/16/2016 4:43:38 PM •
Panasonic...
Answered
on Feb 16, 2016
Where can i find free repair or service manual for
go to www.panasonic.com and then support, then look for manual download. type in the model, then it should give you the manual. if for some reason they do not have it, then just google the model number with manual after the model and you should be able to find it there. hope this helps.. Ron
2/16/2016 3:46:02 PM •
Panasonic...
Answered
on Feb 16, 2016
Cannot remove battery from laptop
You can always refer to manual for such kind of thing.It will bw given with diagram.
If you don't have the manual, download it from the link below
http://www2.panasonic.com/webapp/wcs/stores/servlet/TCCHomePage?langId=-1&storeId=15001
You need to register to their site inorder to downalod the manual.
2/8/2016 2:08:28 AM •
Panasonic...
Answered
on Feb 08, 2016
Panasonic Toughbook CF-51 shutting down
Sue, it's not the inverter board. People who don't really know much
about laptops will often diagnose them incorrectly, especially computer
repair shops. The problem you're experiencing is most likely related
to your motherboard. Unfortunately the most expensive part to replace on most laptops.
Your best bet is to probably just have any important files from the laptop extracted by a repair shop and then selling the computer "As-IS" on ebay. Or you could try another local repair shop to take a look at it. I wouldn't pay any money for a diagnostics since it would take most techs about 5-10 minutes to confirm what I just typed.
2/8/2016 1:55:54 AM •
Panasonic...
Answered
on Feb 08, 2016
Sound card driver issue
doesnt panasonic have a website with a support n drivers section?
make sure ur sound driver is fully uninstalled and files n folders of old driver deleted then switch off and back on and let your os system find a new device..
5/19/2015 2:41:37 PM •
Panasonic...
Answered
on May 19, 2015
