20 Most Recent
Neff U1421 Double circotherm Electric Oven Questions & Answers
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Neff oven wiring diagram
It does not really matter which wire goes where. The red one would be live and the blue would be neutral, but on an oven element they could go on either terminal. Just make sure that everything is turned off when working on the oven etc.
