20 Most Recent Neff U1661 Double circotherm super Electric Oven Questions & Answers
Request a wiring diagram directly from Neff.
Neff U1661... | Answered on Dec 15, 2017
We have a similar Neff Oven - it is a child proof lock that you have activated. To deactivate - turn the left hand dial that selects the mode of cooking - three times to the left and back (turn it from 12 oclock to 11 oclock and back) in quick succession.
Neff U1661... | Answered on Dec 14, 2017
temperature ntc failing will need replacement.
Neff U1661... | Answered on Mar 04, 2017
There are no screws holding the glass on. You need to pull off the inner glass. It just clips on so just pop a round knife at the top and it should just pop off. Tightening the screws should be easy but you probably need a torx screwdriver from memory
Neff U1661... | Answered on Jul 01, 2016
hi there green and yellow is allways the earth connection which is usually the middle tag, what are the colours of the remaining wires and how many are there???
Neff U1661... | Answered on Apr 08, 2016
Hinges not fitted properly,or possibly wrong hinges
Neff U1661... | Answered on Jan 17, 2016
I had this EXACT same problem and the hinge receivers WERE THE PROBLEM!
Easy fix. All you need is a Phillips head screw driver (cross head that is) and about 30 minutes.
1. First off remove the oven door.
2. pull out over so that you can easily access the rear
3. Disconnect oven from the electricity (make sure the mains power is OFF before you do this)
4. Remove the back panel by unscrewing all the screws
5. turn oven over onto its side and remove the bottom panel (more screws)
6. You can now get to the receiver - its held inplace by 1 screw just inside the oven door above the receiver (and maybe another 1 on the side, but i cant remember).
7. Undo screw(s),slide out receiver, replace and put back together in the reverse order.
Honestly, it is very easy (I did it with no help, idea and 1 have 10 sausages for fingers).
Neff U1661... | Answered on Dec 05, 2015
Nothing Works, or the Oven / Range / Stovetop Works Only At Certain Times:
1.Home breaker flipped or the fuse blown?Possibly an electrical surge has flipped the breaker. Check your breaker or fuse box and replace or reset as necessary.
2.Power cord plugged in?Grab the plug and wiggle to determine a good connection.
3.Power cord damage?Damaged rubber with wires showing through or the wire is being pinched can cause issues. Electrical tape is acceptable for covering damaged wires.
4.Aclicking sound could be something wrong with a relay. Check for any loose connections around the main control board on your oven. The click you hear is a relay losing power and switching back on. If the clock resets then something is causing power interruptions to the board.
If your oven has internal fuses, a wiring or component problem could have caused a fuse to blow. A blown fuse is an indication that a component has shorted or failed, and the problem will need to be corrected. Most ovens that use fuses will have an indication of the circuits that are affected by a particular fuse. If an oven fuse has blown, then you should inspect the oven element and the associated wiring to determine the cause before replacing the fuse.
THINGS TO CHECK:
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
The bake element
is the heating element that is found at the bottom of the oven. Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake element performing 90% of the heating. If the bake element isn't working, the oven may not heat. To help determine if the bake element is defective you should first do a visual check. If the element is blistered or separated then it should be replaced. If the element appears to look normal, then turn the oven on to a bake function for a minute and then turn it off.
Check the element for signs of heating and if it is still cold then it may be defective. Disconnect the power and then remove the back panel. First check the wires as they may have become loose or corroded. If the element appears to be fine visually, test it for continuity with a multi-meter. If the element is burned or no longer has continuity, it will need to be replaced.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Surface burners
are typically either a coil type, solid type or a ribbon coil as used in smooth top ranges. All of these consist of a heating wire that uses electric current to produce heat. Coil type elements can be checked for continuity by removing them from the terminal block and testing them with a multi-meter.
You should also inspect the terminal ends for signs of heat damage or corrosion, and if present, you should replace the terminal block or receptacle at the same time. You will need to remove power from the range to change the terminal block. Solid elements and smooth top elements require raising or removing the main top to gain access. You will need to remove power from the range before lifting the main top. Continuity can then be checked with a multi-meter, once you have removed the wires from the element terminals.
On modern electronic control ranges, the oven temperature sensor
is the part that regulates the oven temperature. If it is not working properly it could be the reason why the range or oven won't start. This part can be found inside the oven on the rear wall near the top. Most modern ovens will display a fault code if the oven sensor is at fault. If you think the sensor may be the issue you can check the resistance with a multi-meter but will need to know the correct resistance of the sensor at room temperature. Remove power from the appliance before performing this test.
The infinite switch
on the control panel controls the power to each surface element. If you have no heat at an element and the element and terminal block check ok, then you may have a defective infinite switch. Disconnect power to the range and remove the console back panel. Locate the switch and check for overheated wires or faulty terminals first. Test the switch's contacts for continuity with a multi-meter. If defective, replace the switch.
If the infinite switch does not appear to be defective, then you should check for proper voltage to the switch. This is a live high voltage test and should only be performed by qualified persons.
Most modern ovens use an electronic control board
to control the oven functions. These models will use the control board to operate the oven safety valve on a gas range or oven, and the bake and broil elements on an electric range or oven. If there is no power to the igniter circuit, or the element circuits, then you should check the control board to verify that there is power at the appropriate output relay. These are live voltage checks and should be performed by qualified persons only. If there is no output voltage then the control should be replaced.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Neff U1661... | Answered on Apr 17, 2015
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Neff U1661... | Answered on Mar 22, 2014
Your electric stove has power through 220, wired separately from the rest of the outlets. Go to the breaker for this, shut down total power, and see if that helps. Sometimes it does not take much to reset.
Neff U1661... | Answered on Mar 06, 2014
Neff U1661 Double circotherm super Electric Oven Logo
102 questions posted
Top Neff Ovens Experts
Robert Lurer
Level 1 Expert
Paul Carew
Marvin
Marvin
Are you a Neff Oven Expert? Answer questions, earn points and help others
View Most Popular
Neff Ovens
  • Neff Ovens
Most Popular Question
neff oven u1661 shows fault code 5
  • Ovens
