20 Most Recent
Sony VAIO PCV-W20 PC Desktop Questions & Answers
Please can you tell me the location of the cmos
Hi,Generally all Cmos batter available in front panel place. If you are used PC then open cabinet and see mother board front panel silver color small batter available.If you are used Laptop then same place available other wise RAM slot nearest.Thanks..
1/31/2014 9:18:30 AM •
Sony VAIO...
Answered
on Jan 31, 2014
I have a Sony PCV-W20
It uses a battery CR2032... You must remove the side panel and you should see the battery somewhere on the motherboard. It's the size of a quarter or so.. Let me know if this solved the problem and good luck..
9/9/2011 3:51:04 PM •
Sony VAIO...
Answered
on Sep 09, 2011
UkI have a Vaio VGC-VA1
hi you can buy the CMOS battery from this
linkCMOS battery are just the same regardless of brand
try also at ebay they have various CMOS battery see it
hereIf the holder of the cmos battery is not exactly the same of your original battery you can just remove the battery from the holder and use the holder of the original battery.thank you.
8/17/2011 7:33:54 PM •
Sony VAIO...
Answered
on Aug 17, 2011
How do i reboot my
You reboot it by simply unplugging it from the mains and restarting it.
You reinstall Windows using a generic Windows disk and the key on the label on the case. You will have to add the drivers yourself later.
5/28/2011 8:03:48 AM •
Sony VAIO...
Answered
on May 28, 2011
Hi I have formated my
Hi :) You will have to re-install windows fresh from the beginning. Make sure the windows CD is a full install copy and not a upgrade copy and put it in the CD player then reboot the computer and go into the Bios and have the computer boot from CD ROM reboot and the computer.It will start to load the program. when it ask to install new copy of windows say yes and fallow the questions and answer them.Make sure you have the install KEY for Windows ussaly on a sticker on the computer tower
3/17/2011 6:23:46 PM •
Sony VAIO...
Answered
on Mar 17, 2011
Water went in the keyboard some letters are
You will need to blow dry it out completely. Hopefully this will assist you in this repair if not you may have to purchase a new keyboard. I hope this assisted you. John
2/6/2011 6:48:47 PM •
Sony VAIO...
Answered
on Feb 06, 2011
Key board does not respond
We wish you a Very Happy New Year.
Try to unplug and plug it back in,if it is not working then install the drivers if you have a disk.
If it is not working fine then post back.
Hope this helps.
Cheers!!!!
1/2/2011 2:34:10 PM •
Sony VAIO...
Answered
on Jan 02, 2011
I have an older Sony
Hi
To change the default directory you can follow this procedure--
1. Go to "start menu"-> "run", type in "regedit.exe" (without quotes).
2. Look for the these in order:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion
3. In the right-side panel look for "ProgramFilesDir" and change it from "C:\Program files" to "D:\Program files".
Hope this helps... Please post back if you need more information.
Daniel
12/12/2010 3:43:35 PM •
Sony VAIO...
Answered
on Dec 12, 2010
I have a low disk
It may not work because the BIOS may not support a hard drive with this large capacity. Check the specification of your computer. The other option is to install it and then check the BIOS.
If you install this hard drive in a USB hard drive adapter case, and plug it into the USB port, most likely it will see it as and external storage device with over 200 GB capacity. You lose a small capacity when you format the hard drive.
12/12/2010 12:38:29 PM •
Sony VAIO...
Answered
on Dec 12, 2010
