20 Most Recent
Frigidaire FAFW3801LW Front Load Washer FAFW3801LW Questions & Answers
Reset a fridgadaire front loader washer
Thank you for your inquiry, Cynthia!
From what you have described your Frigidaire washer will not drain. I would recommend checking the drain hose to make sure it is not too long or restricted. If the drain hose checks out it could be a possible problem with your drain pump or motor. To perform a reset on your washer you need to disconnect power from it for at least ten minutes. If that does not help correct your issue you may need to seek assistance from a professional technician for proper diagnosis and repair. I hope this information is helpful. -Matt
Frigidaire stuck pump
PROPELLER OBSTRUCTION? REMOVE AND HAVE A CLOSE LOOK AT IT U MAY BE ABLE TO REMOVE WHATEVER ITEMS IS PLUGGING IT
FAFW3801LW3 has error e59
Hi Rosie,
I understand that you're receiving an E59 error code on your Frigidaire washer, model# FAFW3801LW3 and are looking how to run the diagnostic test. While there isn't too much information about actually running the diagnosis, I would recommend contacting the manufacturer and seeing if they are able to assist.
-Best Regards-
My front load washer do not spin
Take the power plug off the wall. Be prepared for a lot of water before attempting the following. It doesn't spin because the unit is not draining water. It will not spin with water in it - must drain first. Check drain hose for kink,check exit pipe for blockage. Remove the front access panel, bottom front; if you find a pipe there with a cap -this is for draining water. Could be your "coin trap assembly" is blocked, therefore not allowing all the water to pump out. Remove the clamp that connects the trap assembly to the pump and clean it out. If helped, pl say so.
My Frigidaire Affinity washer makes a loud buzzing sound when you push the start button and will not start, what can I do
Good Morning Anonymous, this is Z. I am happy to assist you!
I understand that your door indicates it is open and your dryer will not operate. Let's attempt resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is good to wait approximately ten minutes and turn on your dryer. Select a normal cycle and verify if your dryer will start. If your dryer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, it would be advisable to contact an experienced appliance repair tech to assist further.
What's stopping my dryer from running continuously
Please power cycle your dryer and attempt to run it again. If this fails, please ensure that your clothes are evenly distributed so that they weight of the clothes doesn't cause the dryer to be shutdown. Just to double check, please ensure that you've cleaned the lint track of your dryer. Lastly, you can use an power outlet extender to help switch the power outlet that you're using to run your dryer as there might be something wrong with your current one.
Thank you.
My Frigidaire dryer won't run longer than 5 secs what's wrong how can I fix
There could be several issues that could cause your Frigidaire dryer to stop running after just a few seconds. Here are a few potential problems to consider:
- Thermal fuse: The thermal fuse is a safety device that shuts off the dryer if it overheats. If the fuse has blown, the dryer will not run.
- Clogged dryer vent: If the dryer vent is clogged, it can cause the dryer to overheat, which could trip the thermal fuse.
- Faulty cycling thermostat: The cycling thermostat regulates the dryer's temperature. If it's faulty, the dryer may not run for more than a few seconds.
- Faulty start switch: If the start switch is faulty, it could prevent the dryer from running.
- Faulty door switch: The door switch prevents the dryer from running when the door is open. If the switch is faulty, the dryer may not run.
To fix the problem, you'll need to diagnose which of these issues is causing the problem and then replace the faulty part. I recommend having a mechanic diagnose and fix the problem for you.
WHAT IS E11 ERROR CODE IN MICROWAVE FRIGIDAIRE
The E11 error code indicates a problem with the gas sensor DE32-60011A and or the wire harness DE39-40678D. Unfortunately the manufacturer has discontinued the sensor. You may want to try contacting local parts dealers, one of them might still have it in stock. Enter your part number in a search engine, a smaller company might have it or try eBay, Amazon or similar sites . Search by using the manufacturers part number. Try a used appliance store, sometimes they have the same model or a usable part for your machine.
