20 Most Recent
LG WT5070CW 4.7 Cu. Ft. Ultra Large Capacity High Efficiency Top Load Questions & Answers
Fix LE error for LG washer
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective
Washer does not add enough hot water
He is right, we can thank the energy mandate for than. In all new washers they are only required to reach 69 degree. All detergent are now activated at 62 degree no matter what. Some washers do get hotter but not lg
